ST STEVAL-IHM028V1 2kW 三相马达控制方案
关键词:工业控制 马达驱动 马达控制
时间:2011-11-24 11:45:12       作者:ST       来源:STEVAL-IHM028V1
ST公司的STEVAL-IHM028V1 2kW三相马达控制板是采用小型低损耗智能模块(SLLIMM)IPM STGIPS20K60--18A 600V 三相IGBT反相器。最低输入电压125VDC或90VAC,最大输入电压400VDC或285VAC,采用电压倍增器时的范围从65 VAC到145 VAC,最大输出功率达2000W,主要用在HVAC的风扇,电动工具,工业驱动,大功率工业泵,专业洗衣机。本文介绍了STGIPS20K60主要特性,方框图,典型应用电路以及STEVAL-IHM028V1主要特性,电路图,材料清单和PCB布局图。
STGIPS20K60:SLLIMM™ (small low-loss intelligent molded module) IPM, 3-phase inverter - 18 A, 600 V short-circuit rugged IGBT
This intelligent power module provides a compact, high performance AC motor drive in a simple, rugged design. Combining ST proprietary control ICs with the most advanced short-circuit-rugged IGBT system technology, this device is ideal for 3-phase inverters in applications such as home appliances and air conditioners. SLLIMM™ is a trademark of STMicroelectronics.
STGIPS20K60主要特性:
■ IPM 18 A, 600 V 3-phase IGBT inverter bridge including control ICs for gate driving and freewheeling diodes
■ Short-circuit rugged IGBTs
■ VCE(sat) negative temperature coefficient
■ 3.3 V, 5 V, 15 V CMOS/TTL inputs comparators with hysteresis and pull down /pull up resistors
■ Undervoltage lockout
■ Internal bootstrap diode
查看全文
