TI TPS62730高频超低功耗DC电源解决方案
关键词:电源管理 DC/DC转换器
时间:2011-08-30 10:13:49       作者:TI       来源:TPS62730
TI公司的TPS62730是高频超低功耗同步降压DC/DC转换器,非常适合用在低功耗小于1GHz和2.4GHz RF收发器。TPS62730输入电压从1.9V到3.9V,超低功耗旁路模式的功耗为30nA,DC/DC转换器静态电流25uA,开关频率高达3MHz,DC/DC效率高达95%,输出峰值电流高达100mA,主要用在CC2540蓝牙低功耗系统级解决方案,低功耗无线应用和RF4CE表。本文介绍了TPS62730主要特性,功能方框图,典型应用电路以及TPS62730EVM-726评估模块主要特性,电路图和材料清单。
The TPS62730 is a high frequency synchronous step down DC-DC converter optimized for ultra low power wireless applications. The device is optimized to supply TI’s Low Power Wireless sub 1GHz and 2.4GHz RF transceivers and System-On-Chip-solutions. The TPS62730 reduces the current consumption drawn from the battery during TX and RX mode by a high efficient step down voltage conversion. It provides up to 100mA output current and allows the use of tiny and low cost chip inductors and capacitors. With an input voltage range of 1.9V to 3.9V the device supports Li-primary battery chemistries such as Li-SOCl2, Li-SO2, Li-MnO2 and also two cell alkaline batteries.
The TPS62730 features an Ultra Low Power bypass mode with typical 30nA current consumption to support sleep and low power modes of TI’s CC2540 Bluetooth Low Energy and CC430 System-On-Chip solutions.
TPS62730主要特性:
查看全文
