Freescale MK30X256单相电表参考设计方案
关键词:Freescale MK30X256 单相电表参考设计 智能电表 Kinetis MCU 智能能源
时间:2011-08-19 10:14:00       作者:Freescale       来源:MK30X256
Freescale公司的MK30X256是集成了段式LCD控制器的低功耗基于100MHz ARM Cortex™-M4内核的MCU,支持多达320段LCD.K30系列采用创新的90nm薄膜存储(TFS)闪存技术和FlexMemory (EEPROM),提供一流的低功耗和混合信号集成, 器件提供1.25 Dhrystone MIPS per MHz的性能,工作电压和闪存写入电压均为1.71- 3.6 V,多达16路DMA,主要用在自动调温器,智能仪表,心率监视仪和血气分析仪.本文介绍了K30 MCU主要特性和优势, 方框图以及MQXTM + ZigBee® MK30X256单相电表参考设计主要特性, 单相电表方框图和电表主要指标.
Kinetis K30 Family Low-power MCUs with segment LCD
The Kinetis MCU portfolio consists of multiple pin-, peripheral- and software-compatible MCU families based on the ARM Cortex™-M4 core.
Families are built from innovative 90 nm thinfilm storage (TFS) flash technology with unique FlexMemory (EEPROM) capability, and offer industry-leading low power and mixed signal analog integration.
The K30 MCU family is pin-, peripheral- and software-compatible with the K10 MCU family and adds a flexible low-power segment LCD controller with support for up to 320 segments. Devices start from 64 KB of flash in 64 QFN packages extending up to 512 KB in a 144 MAPBGA package with a rich suite of analog, communication, timing and control peripherals.
K30 MCU主要特性:
• Operating Characteristics
查看全文
