Linear LT8500 48路LED PWM发生器解决方案
关键词:电源管理 LED驱动器 PWM发生器
时间:2011-08-08 10:22:28       作者:Linear       来源:LT8500
Linear 公司的LT8500是具有12位分辨率和解0MHz级联串口的48路LED PWM发生器,输入电压3V-5.5V,有48个单独的PWM输出,高达6.1kHz的PWM频率(PWMCK = 25MHz),主要用在大屏显示器LED背光,单色,多色和全色LED显示器,马大哈控制,工业控制,ATE和机器人.本文介绍了LT8500主要特性,方框图以及多种应用电路.
48-Channel LED PWM Generator with 12-Bit Resolution and 50MHz Cascadable Serial Interface
The LTR8500 is a pulse width modulation (PWM) generator with 48 independent channels. Each channel has an individually adjustable 12-bit (4096-step) PWM register and a 6-bit (64-step) ±50% correction register. All controls are programmable via a simple serial data interface. Three banks of 16-channels each can be configured such that they operate 120° out-of-phase with each other.
The LT8500 features two diagnostic information flags: synchronization error and open LED. The flags are sent, with additional state information, on the serial data interface during status read back. The 50MHz cascadable serial data interface includes buffering and skew-balancing, making the chip suitable for PWM intensive applications such as large screen LCD dynamic backlighting and mono-,multi- and full-color LED displays. The LT8500 is also ideally suited to control three LT3595A LED drivers.
查看全文
