时间:2011-05-31 09:55:58 作者:Linear 来源:LTCR3805-5
Linear 公司的LTCR3805-5是可调频率电流模式反激/升压/SEPIC DC/DC控制器,工作频率(70kHz-700kHz)和斜率补偿由外接电阻编程,输出电压精度±1.5%,主要用在汽车电源,通信电源,隔离的电子设备,家用电器电源和PoE。本文介绍了LTCR3805-5主要特性,方框图,多种应用电路以及评估板电路图和材料清单。
Adjustable Frequency Current Mode Flyback/ Boost/SEPIC DC/DC Controller
The LTCR3805-5 is a current mode DC/DC controller designed to drive an N-channel MOSFET in flyback, boost and SEPIC converter applications. Operating frequency and slope compensation can be programmed by external resistors. Programmable overcurrent sensing protects the converter from overload and short-circuit conditions.
Soft-start can be programmed using an external capacitor and the soft-start capacitor also programs an automatic restart feature.
The LTC3805-5 provides ±1.5% output voltage accuracy and consumes only 360μA of quiescent current during normal operation and only 40μA during micropower startup. Using a 9.5V internal shunt regulator, the LTC3805-5 can be powered from a high VIN through a resistor or it can be powered directly from a low impedance DC voltage from 4.7V to 8.8V.
The LTC3805-5 is available in the 10-lead MSOP package and the 3mmx3mm DFN package.
LTCR3805-5主要特性:..
分享到:
