IR IRS2573D 全集成全保护600V 70W HID灯控制方案
关键词:电源管理 HID灯 镇流器
时间:2011-05-24 13:54:13       作者:IR       来源:IRS2573D
IR公司的IRS2573D 是全集成全保护600V HID灯控制集成电路,集成了点火时序控制,恒流灯功率控制,可编全桥运行频率,可编过压和欠压保护以及可编过流保护。器件还具有600V高边和低边全桥驱动器,600V高边降压驱动器,低边点火FET栅极驱动器。本文介绍了IRS2573D主要特性,方框图,典型应用电路图和70W HID镇流器主要特性,方框图,电路图,材料清单和PCB布局图。
The IRS2573D is a fully-integrated, fully-protected 600V HID control IC designed to drive all types of HID lamps. Internal circuitry provides control for ignition, warm-up, running and fault operating modes. The IRS2573D features include ignition timing control, constant lamp power control, programmable full-bridge running frequency, programmable over and under-voltage protection and programmable over-current protection. Advanced protection features such as failure of a lamp to ignite, open load, short-circuit and a programmable fault counter have also been included in the design.
IRS2573D主要特性:
Buck, full-bridge and lamp control in one IC
Continuous/critical-conduction mode buck control
600V high and low-side full-bridge driver
600V high-side buck Driver
Low-side ignition FET gate driver
Integrated bootstrap FETs for full-bridge high-side drivers
Constant lamp power control
查看全文
