Linear LTC2145-14低功耗125Msps 14位模数转换方案
关键词:通信技术 无线通信 蜂窝基站 工业控制 数据采集
时间:2011-04-18 10:36:13       作者:Linear        来源:LTC2145
Linear公司的LTCR2145-14/LTC2144-14/LTC2143-14是低功耗2路同时取样的14位模数转换器(ADC),SNR达到73.1dB,SFDR为90dB,取样速率达125Mbps,DC指标包括±1LSB INL, ±0.3LSB DNL,整个温度范围内不会丢失码,CMOS输出摆幅从1.2V到1.8V,主要用在通信,蜂窝基站,软件定义无线电(SDR),手提医疗图像设备,多路数据采集和非破坏性测试.本文介绍了LTC2145-14主要特性, 功能方框图,典型应用电路以及输入频率5MHz-150MHz, 150MHz-250MHz和大于250MHz的前端电路图, 1620A演示板电路图和材料清单(BOM).
The LTCR2145-14/LTC2144-14/LTC2143-14 are 2-channel simultaneous sampling 14-bit A/D converters designed for digitizing high frequency, wide dynamic range signals.
They are perfect for demanding communications applications with AC performance that includes 73.1dB SNR and 90dB spurious free dynamic range (SFDR). Ultralow jitter of 0.08psRMS allows undersampling of IF frequencies with excellent noise performance.
DC specs include ±1LSB INL (typ), ±0.3LSB DNL (typ) and no missing codes over temperature. The transition noise is 1.2LSBRMS.
The digital outputs can be either full rate CMOS, double data rate CMOS, or double data rate LVDS. A separate output power supply allows the CMOS output swing to range from 1.2V to 1.8V.
查看全文
