NXP TDA5051A家庭自动化调制解调解决方案
关键词:消费类电子 家庭自动化 动力线通信 PLM
时间:2011-01-18 11:44:10       作者:NXP        来源:TDA5051A
NXP 公司的TDA5051A是专用于ASK发送的调制解调器IC,适用于家庭动力线网络,传输速率600或1200波特,工作电压5V,集成了6位DAC和8位ADC,接收器输入端有自动增益控制(AGC),和EN50065-1兼容,外接元件少。主要应用在家用电器控制(如空调,照明,告警等),能量/加热控制以及采用家庭动力线网络的ASK数据发送。本文介绍了TDA5051A主要特性,方框图,多种应用电路以及TDA5051A动力线调制解调器评估板电路图和材料清单。
TDA5051A:Home automation modem
The TDA5051A is a modem IC, specifically dedicated to ASK transmission by means of the home power supply network, at 600 baud or 1200 baud data rate. It operates from a single 5 V supply.
TDA5051A主要特性:
Full digital carrier generation and shaping
Modulation/demodulation frequency set by clock adjustment, from microcontroller or on-chip oscillator
High clock rate of 6-bit D/A (Digital to Analog) converter for rejection of aliasing components
Fully integrated output power stage with overload protection
Automatic Gain Control (AGC) at receiver input
8-bit A/D (Analog to Digital) converter and narrow digital filtering
Digital demodulation delivering baseband data
Easy compliance with EN50065-1 with simple coupling network
Few external components for low cost applications
SO16 plastic package
TDA5051A应用:
查看全文
