Quicklogic ArcticLink可编程连接平台解决方案
关键词:通信技术 USB连接 OTG
时间:2010-04-22 14:36:47       作者:Quicklogic       来源:中电网
Quicklogic公司的ArcticLink可编程连接解决方案平台采用0.18um六层金属CMOS工艺制造,内核电压为1.8V,I/O电压可设定为1.8V,2.5V和3.3V. ArcticLink的逻辑单元为640个,集成了高速USB 2.0 OTG控制器, SD/SDIO/MMC/CE-ATA主控制器, ASSP/FPGA接口,以及灵活的可编程架构,可编程I/O,非常低功耗模式和安全链接.本文介绍了ArcticLink主要特性, 解决方案平台方框图, 连接解决方案方框图,以及各种USBOTG连接框图,在汽车内装蓝牙免提,智能手机,PND/PMP和ePOS的应用框图.
The QuickLogic ArcticLink Solution Platform is fabricated on a 0.18 μm, six layer metal CMOS process. The core voltage is 1.8 V. The I/O voltage input tolerance and output drive can be set as 1.8 V, 2.5 V, and 3.3 V.
ArcticLink 器件亮点:
Hi-Speed USB 2.0 OTG Controller
• Single port OTG with embedded high-speed PHY
• Optional 12-signal ULPI interface
• Full-speed CEA-936-A mini-USB analog carkit interface
• Dedicated DMA controller
• High-speed up to 480 Mbits/sec.
SD/SDIO/MMC/CE-ATA Host Controller
• SD/SDIO 1-bit or 4-bit up to 52 MHz with Secure Digital High Capacity (SDHC) support
• CE-ATA 1-bit, 4-bit or 8-bit up to 52 MHz
• MMC 1-bit, 4-bit or 8-bit up to 52 MHz
• High-speed and flexible to support multiple storage options and SDIO peripherals
查看全文
