Poweint PLC810PG 150W LED街灯照明设计方案
关键词:电源管理 LED驱动器 LED街灯照明 PFC LLC
时间:2009-11-25 11:05:00       来源:Powerint
Powerint 公司的PLC810PG 是集成了半桥驱动器的PFC和LLC离线控制器,其中的PFC部分是通用输入连续电流模式(CCM),不需要正弦输入参考,从而降低成本和外接元件.主要应用32-60吋LCD TV电源,150-600W电源和LED街灯照明.本文介绍PLC810PG主要特性, 方框图, 150W LED街灯照明设计DER-212主要特性和指标, PLC810PG LED 街灯照明电源输入电路和PFC功率级, PFC控制输入电路和LLC级以及所用材料清单(BOM).
DER-212:150 W Power Factor Corrected LLC Power Supply Using HiperPLC (PLC810PG)
The PLC810PG is a combined PFC and LLC off-line controller with integrated high voltage half-bridge drivers. Figure 1 shows a simplified schematic of a PLC810PG based power supply where the LLC resonant inductor is integrated into the transformer. The PFC section of the PLC810PG is a universal input continuous current mode (CCM) design that does not require a sinusoidal input reference, thereby reducing system cost and external components.
The DC-DC controller drives an LLC resonant topology. This variable frequency controller provides high efficiency by switching the power MOSFETs at zero voltage, eliminating most switching losses. The LLC controller is built around a current controlled oscillator with a control range selected to support the traditional frequency of operation found in televisions.
查看全文
