TI TPS54383双路异步转换器应用方案
关键词:电源管理 AC/DC转换器
时间:2009-07-15 16:14:00       来源:TI
TI公司的TPS54383 和TPS54386是双输出异步降压DC/DC转换器,输入电压从4.5V到28V,输出电流可高达3A,输出电压则在0.8V和输入电压的90%之间.主要应用在机顶盒,数字TV,DSP电源和消费类电子产品.本文介绍了TPS54383 和TPS54386的主要性能,功能方框图以及多种详细的设计案例.
TI 3-A DUAL NON-SYNCHRONOUS CONVERTER WITH INTEGRATED HIGH-SIDE MOSFET
The TPS54383 and TPS54386 are dual output, non-synchronous buck converters capable of supporting 3-A output applications that operate from a 4.5-V to 28-V input supply voltage, and require output voltages between 0.8 V and 90% of the input voltage.
With an internally-determined operating frequency, soft start time, and control loop compensation, these converters provide many features with a minimum of external components. Channel 1 overcurrent protection is set at 4.5 A, while Channel 2 overcurrent protection level is selected by connecting a pin to ground, to BP, or left floating. The setting levels are used to allow for scaling of external components for applications that do not need the full load capability of both outputs.
The outputs may be enabled independently, or may be configured to allow either ratiometric or sequential startup sequencing. Additionally, the two outputs may be powered from different sources.
查看全文
