Powerint LNK605DG 3.7W LED驱动设计方
关键词:Powerint DER206 3.7W LED驱动 LNK605DG
时间:2009-07-15 13:35:00       来源:Powerint
Powerint 公司的DER206 3.7W LED驱动设计方案是采用LNK605DG器件,输入电压为90-265VAC,输出电压为10.5V/350mA. DER206设计初级采用恒压/恒流(CV/CC)控制器,从而省略了次级控制和光耦.输出电压精度±5%,输出电流精度±10%,包括火线电压,负载和温度补偿和元件误差.主要应用手机,无绳电话,PDA,MP3的充电器,适配器,LED驱动器等.本文介绍了LNK605DG的主要特性,应用案例和DER206设计电路图与材料清单.
3.7 W LED Driver Using LNK605DG:90–265 VAC Input; 10.5 V, 350 mA Output DER206设计优势:
Summary and Features
Accurate primary-side constant voltage/constant current (CV/CC) controller eliminates secondary side control and optocoupler
±5% output voltage and ±10% output current accuracy including line, load, temperature and component tolerance
No current-sense resistors for maximized efficiency
Low part-count solution for lower cost
Over-temperature protection–tight tolerance (±5%) with hysteretic recovery for safe PCB temperatures under all conditions
Auto-restart output short circuit and open-loop protection
EcoSmart – Easily meets all existing and proposed international energy efficiency standards–China (CECP) / CEC / EPA / European Commission
ON/OFF control provides constant efficiency to very light loads
No-load consumption <200 mW at 265 VAC
查看全文
