NXP 公司的PCA9626是I2C总线控制的24位LED驱动器,每个LED输出有它本身的8位分辨率的固定频率PWM控制器,工作频率97kHz,占空比从0%到99.6%可调整,使LED能设定到所需亮度. PCA9626工作电压从2.3V到5.5V,100mA漏极开路输出使电压高达40V, 内部25MHz振荡器不需要外接元件.本文介绍了PCA9626的主要特性,方框图以及典型应用.
PCA9626
24-bit Fm+ I2C-bus 100 mA 40 V LED driver
The PCA9626 is an I2C-bus controlled 24-bit LED driver optimized for voltage switch dimming and blinking 100 mA Red/Green/Blue/Amber (RGBA) LEDs. Each LED output has its own 8-bit resolution (256 steps) fixed frequency individual PWM controller that operates at 97 kHz with a duty cycle that is adjustable from 0 % to 99.6 % to allow the LED to be set to a specific brightness value. An additional 8-bit resolution (256 steps) group PWM controller has both a fixed frequency of 190 Hz and an adjustable frequency between 24 Hz to once every 10.73 seconds with a duty cycle that is adjustable from 0 % to 99.6 % that is used to either dim or blink all LEDs with the same value.
查看全文
