TI LP55231 评估参考设计方案
关键词:电源管理 LED驱动器 LP55231
时间:2013-08-26 14:21:59       作者:TI       来源:LP55231
TI公司的LP55231是一款应用于照明效果移动设备的9通道LED驱动芯片,内部集成高效电荷泵以驱动高于锂电池供电的LED设备,该芯片内部集成程序存储器,允许在没有微控制器的情况下进行操作。本文首先介绍芯片的简介、特性、内部框图及应用领域,并给出相应设计方案的设计原理图、元器件列表及制板图。
The LP55231 is a 9-channel LED driver designed to produce lighting effects for mobile devices. A high-efficiency charge pump enables LED driving over full Li-Ion battery voltage range. The device is equipped with an internal program memory, which allows operation without processor control.
The LP55231 maintains excellent efficiency over a wide operating range by autonomously selecting the best charge pump gain based on LED forward voltage requirements. The device is able to automatically enter power-save mode when LED outputs are not active, thus lowering idle current consumption down to 10 μA (typ).
LP55231主要特性:
• Three Independent Program Execution Engines, 9 Programmable Outputs With 25.5mA Full-scale Current, 8-bit Current Setting Resolution and 12-bit PWM Control Resolution
• Adaptive High-efficiency 1x/1.5x Fractional Charge Pump - Efficiency up to 94%
• LED Drive Efficiency Up to 93%
• Charge Pump With Soft Start and Over-current/Short-circuit Protection..
查看全文
