时间:2012-02-14 11:02:33 作者:Powerint 来源:LNK419EG
Powerint公司的18W替代T8荧光管灯的LED驱动器采用LinkSwitchTM-PH系列LNK419EG,输入电压90VAC到265VAC,输出电压200V/90mA.拓扑采用单级非隔离降压-升压,具有紧凑和低元件数的特点,线路和负载调整有于2%,110VAC的效率大于89.5%, THD小于20%,而230VAC时的效率大于90%,THD小于28%.本文介绍了设计方案DER298的主要特性,优势和指标,电路图和材料清单.
Constant Current (<2% Regulation), Non-Isolated Buck-Boost, Power Factor Corrected,18 W LED Driver Using LinkSwitchTM-PH LNK419EGT8 Tube Retrofit LED Driver
The document describes a universal, non-isolated, high efficiency, high power factor (PF) LED driver designed to drive a nominal LED string voltage of 200 V at 90 mA from an input voltage range of 90 VAC to 265 VAC. The LED driver utilizes the LNK419EG from the LinkSwitch-PH family of ICs.
分享到:
