NXP SSL2101 LED反激驱动解决方案
关键词:电源管理 AC/DC转换器 LED驱动器
时间:2011-06-27 11:07:12       作者:NXP       来源:SSL2101
NXP公司的SSL2101是120VAC LED反激驱动器,能直接工作在火线电压整流器,器件包括高压功率开关,以及直接从火线电压整流器起动的电路.支持大多数调光方案,内置了超温保护(OTP),过流保护(OCP)和绕组短路保护(SWP),主要用在高达10W的装饰灯如GU10,LED驱动器,高达15W的LED串以及1W-10W的LED灯.本文介绍了SSL2101主要特性, 方框图, 反激电路图(230V TRIAC适用)以及SSL2101光参考板主要指标,电路图和材料清单.
UM10477: SSL2101 120 V (AC) flyback task light 20 V/450 mA driver board
The SSL2101 is a Switched Mode Power Supply (SMPS) controller IC that operates in combination with a phase cut dimmer directly from rectified mains. It is designed to drive LED devices. The device includes a high-voltage power switch and a circuit to allow start-up directly from the rectified mains voltage. Furthermore the device includes high-voltage circuitry to supply the phase cut dimmer.
SSL2101主要特性:
Easy migration to existing lighting control infrastructure, triac and transistor dimmers
Supports majority of available dimming solutions
Valley switching efficiency is optimized by built-in dedicated circuitry
Built-in demagnetization detection
The IC has built-in OverTemperature Protection (OTP)
Short-Winding Protection (SWP) and OverCurrent Protection (OCP)
查看全文
