ADI ADF7241零IF 2.4GHz低功耗收发器解决方案
关键词:通信技术 无线通信 ZigBee IEEE 802.15.4 无线传感器网络
时间:2011-02-28 09:41:58       作者:ADI       来源:ADF7241
ADI 公司的ADF7241是高集成低功耗高性能的零IF 2.4GHz低功耗收发器,支持IEEE 802.15.4-2006 2.4 GHz PHY,并和FCC CFR47 Part 15, ETSI EN 300 440 (Equipment Class 2), ETSI EN 300 328 (FHSS, DR > 250 kbps)以及ARIB STD T-66标准兼容,250kbps的灵敏度为-95dBm,输出功率在-20dBm到+4.8dBm间编程,工作电压1.8V-3.6V,主要用在无线传感器网络,自动读表/智能表,工业无线控制,保健,无线音/视频,消费类电子和ZigBee。本文介绍了ADF7241主要特性,功能方框图,以及多种应用电路图。
Low Power IEEE 802.15.4 Zero-IF 2.4 GHz Transceiver IC
The ADF7241 is a highly integrated, low power, and high performance transceiver for operation in the global 2.4 GHz ISM band. It is designed with emphasis on flexibility, robustness, ease of use, and low current consumption. The IC supports the IEEE 802.15.4-2006 2.4 GHz PHY requirements in both packet and data streaming modes. With a minimum number of external components, it achieves compliance with the FCC CFR47 Part 15, ETSI EN 300 440 (Equipment Class 2), ETSI EN 300 328 (FHSS, DR > 250 kbps), and ARIB STD T-66 standards.
查看全文
