TI 公司的TPS6206x 系列是3MHz 高效同步降压DC/DC电源转换器,输出电流高达2A。输入电压从3V到6V,效率高达97%。主要应用在POL,笔记本电脑,手持媒体播放器和DSP电源。本文介绍了TPS6206x 主要特性,方框图,典型应用电路以及评估板TPS62065-67EVM电路图和材料清单(BOM)。
The TPS6206x is a family of highly efficient synchronous step down DC-DC converters. They provide up to 2.0A output current.
With an input voltage range of 3.0V to 6V the device is a perfect fit for power conversion from a 5V or 3.3V system supply rail. The TPS6206x operates at 3MHz fixed frequency and enters Power Save Mode operation at light load currents to maintain high efficiency over the entire load current range. The Power Save Mode is optimized for low output voltage ripple. For low noise applications, TPS62065 can be forced into fixed frequency PWM mode by pulling the MODE pin high. TPS62067 provides an open drain power good output.
In the shutdown mode, the current consumption is reduced to less than 1µA and an internal circuit discharges the output capacitor.
TPS6206x 主要特性:
3 MHz Switching Frequency
VIN Range from 3.0V to 6V
Up to 97% Efficiency
Power Save Mode/3MHz Fixed PWM Mode
Power Good Output
分享到:
