时间:2022-08-25 13:35:26 来源:中电网
ADI公司的AD4684是 1 MSPS/500 kSPS四路16位双同时取样逐次逼近寄存器型(SAR)模数转换器(ADC),工作电压从3.0V到3.6V, AD4684吞吐量速率高达1MSPS, AD4685吞吐量速率高达500KSPS.模拟输入类型是单端和取样,转换在CS下降边沿. AD4684/AD4685具有片上定序器,集成了片上过取样区块,以改善动态范围,在低带宽时降低噪音.器件还包括缓冲内部2.5V基准电压.此外也可用高达3.3V的外接基准电压.转换过程和数据收集采用标准控制输入,允许接口到微处理器或数字信号处理器(DSP). AD4684/AD4685采用16引脚3mmx3mm LFCSP封装,工作温度从−40°C 到+125°C.主要用在马达控制位置反馈,马达控制电流检测,声纳,电源质量,数据采集系统,掺铒光纤放大器(EDFA)应用,相为和正交解调.本文介绍了AD4684产品亮点和主要特性,功能框图和典型应用电路图,以及评估板EVAL-AD7386FMCZ主要特性,电路图,材料清单和评估板EVAL-AD7386FMCZ和EVAL-SDP-CH1Z建立图.
The AD4684/AD4685 are 16-bit, dual, simultaneous sampling, high speed, successive approximation register (SAR), analog-to-digital converters (ADCs) that operate from a 3.0 V to 3.6 V power supply and feature throughput rates of up to 1 MSPS for the AD4684 and
500 kSPS for the AD4685. The analog input types are single-ended and are sampled and converted on the falling edge of CS.
The AD4684/AD4685 have an on-chip sequencer and integrated on-chip oversampling block to improve dynamic range and reduce noise at lower bandwidths. A buffered internal 2.5 V reference is included. Alternatively, an external reference up to 3.3 V can be used. The conversion p..
分享到:
