关键词:自动测试 数据采集 μModule 医疗电子 ADI ADAQ23876
时间:2022-03-03 14:34:25 来源:中电网
ADI公司的ADAQ23876/ ADAQ23878是精密高速μModule®数据采集解决方案,能从设计者转移元件选择,优化和布局的设计负荷到器件而降低精密测量系统的开发周期.采用系统级封装(SIP)技术,通过在单个器件组合多个共同信号处理和调节区块,包括低噪音,全差分ADC驱动器放大器(FDA),稳定基准缓冲器,高速16位15MSPS逐次逼近(SAR) ADC, ADAQ23876降低了终端系统的元件数量. ADAQ23876采用ADI公司的iPassive®技术还集成具有超匹配和漂移特性的关键无源器件,以最大限度降低温度影响误差源和提供最佳的性能.ADC驱动器级的快速设定SAR ADC和无延迟提供了高通路数量,多路信号链架构和控制回路应用. 4.096 V REFBUF输入范围: ±10 V, ±5 V, ±4.096 V, ±2.5 V, and ±1.5 V,增益/衰减选择为0.37, 0.73, 0.87, 1.38和2.25,FDA的精密电阻匹配为0.005%,采用9 mm × 9 mm, 0.8 mm间距的100球CSP_BGA封装.主要用在自动测试设备,数据采集,回路中硬件(HiL),电源分析仪,非破坏性测试,质谱法,行波故障定位,医疗图像和仪器.本文介绍了ADAQ23876主要特性, μModule简化框图和多种配置图,以及评估板EVAL-ADAQ23876FMCZ主要特性,电路图,材料清单和PCB设计图.
The ADAQ23876 is a precision, high speed, μModule® data acquisition solution that reduces the development cycle of precision measurement systems by transferring the design burden of component selection, optimization, and layout from the designer to the device.
Using system-in-package (SIP) technology, the ADAQ23876 reduces end system component count by combining multiple common signal processing and conditioning blocks in a single device, including a low noise, fully differential ADC driver amplifier (FDA), a stable reference..
分享到:
