Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Maxim MAX25603Æû³µËÄ¿ª¹Ø½µÑ¹£­ÉýѹLED¿ØÖÆÆ÷½â¾ö·½°¸
¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí LEDÇý¶¯Æ÷ Maxim MAX25603
ʱ¼ä£º2022-02-28 15:28:53       À´Ô´£ºÖеçÍø
Maxim¹«Ë¾µÄMAX25603ÊÇͬ²½ËÄ¿ª¹Ø½µÑ¹-ÉýѹLEDÇý¶¯Æ÷,ÊÊÓÃÓڶ๦ÄÜÆû³µ×éºÏÍ·µÆ.¿ØÖÆÆ÷µ÷ÕûLED´®µçѹµÄLEDµçÁ÷,´Ó0Vµ½60V. MAX25603ÓÃ×÷Î޷콵ѹ-ÉýѹLEDÇý¶¯Æ÷,ÓÃÓÚÐèÒªÓÐͬ²½ÕûÁ÷µÄÓÐЧÂʽµÑ¹-ÉýѹLEDÇý¶¯Æ÷Æ÷¼þ·Ç³£ÊʺÏÓÚÐèÒªÓÐPWMµ÷¹â¹¦ÄܵçÁ÷Ô´µÄ´ó¹¦ÂÊÓ¦ÓÃ.Æ÷¼þÌṩ½µÑ¹,ÉýѹºÍ½µÑ¹-Éýѹģʽ¼äµÄÎÞ·ìÏνÓ,È¡¾öÓÚÊäÈëºÍÊä³öµçѹµÄ±ÈÀý.¹ÊÕϱêʶָÃ÷¿ªÂ·LED»òÈȹضÏÌõ¼þ.Æ÷¼þ²ÉÓÃADI¹«Ë¾µÄרÓÐµÄÆ½¾ùµçÁ÷ģʽ·½°¸,¿Éµ÷200kHzµ½440kHz¹Ì¶¨ÆµÂʲÙ×÷.´ËÍâ,ÄÚ²¿Õñµ´Æ÷»¹Ôö¼ÓÁË¡À6%Èý½ÇÀ©Æµ,ÒÔ¸ÄÉÆEMIÐÔÄÜ. MAX2560Ìṩ¾ßÓÐʱ¼ä¹²ÏíµÄË«´®LEDÓ¦ÓõÄÄ£ÄâºÍÊý×ÖPWMµ÷¹â.µ¥¸öÆ÷¼þÄܸø°×ÌìÐÐÊ»µÆ(DRL)ºÍλÖõÆ, Ç¿¹âµÆºÍ½ü¹âµÆ¹©µç.Æ÷¼þ¼¯³ÉÁ½¸ö¸ß±ßpMOSÇý¶¯Æ÷,ÓÃÓÚÐèÒª¿ìËÙÉÏÉýÑØºÍϽµÑØLEDµçÁ÷µÄPWMµ÷¹âÓ¦ÓÃ.Æ÷¼þ»¹¾ßÓÐÇ¿½¡¿ªÂ·ºÍ¶Ì·±£»¤, AEC-Q100ÈÏÖ¤,ÊʺÏÓÚÆû³µÓ¦ÓÃ.ÊäÈëµçѹ´Ó5Vµ½60V,HÇŵ¥¸öµç¸Ð½µÑ¹-Éýѹ¼Ü¹¹, ÔÚ˲±ä¹ý³ÌÖÐÓÐÄÚÖÿìËÙLEDµçÁ÷ÏÞÖÆ.¹¤×÷½áζÈ-40ºC µ½+150ºC.Ö÷ÒªÓÃÔÚÆû³µ×éºÏÆû³µÍ·µÆ.±¾ÎĽéÉÜÁËMAX25603Ö÷ÒªÓÅÊÆºÍÌØÐÔ¿òͼºÍ¼ò»¯Ó¦Óÿòͼ,¼¸ÖÖÓ¦Óõç·ÒÔ¼°ÆÀ¹À°åMAX25603 EVKÖ÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The MAX25603 is a synchronous four-switch, buck boost LED driver controller suitable for multifunction automotive combination head lamps. The controller regulates the LED current for LED string voltages from 0V to 60V. The MAX25603 can be used as a seamless buck-boost LED driver for applications that require an efficient buck-boost LED driver with synchronous rectification. The MAX25603 is ideal for high-power applications that require a current source with PWM dimming capability.
The device provides seamless transition between buck, boost, and buck-boost modes depending o..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
