[原创]ST STPD01 USB Type-C供电双端口适配器解决方案
关键词:电源管理 USB供电 USB Type-C ST STPD01
时间:2022-02-17 16:00:39       来源:中电网
ST公司的STPD01是可编程同步降压转换器,提供USB供电系统所需要的电压,满足多达60W(20V/3A)输出功率的USB PD 3.0指标.不同的输出电压和电流限制能通过I2C接口动态设定.器件中还包括过压,过流和超温保护.可编看门狗 改善了整个系统的鲁棒性..器件输入电压从6.0V到26.4V,内部功率MOS同步整流和补偿,I2C总线控制,输出电压设定从3V到20V,每步最小为20mV.转换速率控制(最大为30 mV/us).器件嵌入了放电功能.两个可编开关频率和选择时钟抖动.看门狗计时器由I2C设定,具有软起动功能和可配置中断引脚. STPD01采用3 x 4 mm QFN24L封装.主要用在AC适配器, B集线器,PC监视器,智能TV和USB-PD电源分配.本文介绍了STPD01主要特性,框图,典型应用电路图及其材料清单,以及评估板STEVAL-2STPD01主要特性, 架构框图,电路图和材料清单.
The STPD01 is a programmable synchronous buck converter suitable to provide power supply in applications following USB power delivery specifications.
The device provides those voltages required by USB power delivery systems as stated in USB PD 3.0 spec up to 60 W output power (20 V, 3 A).
The different levels of output voltage and current limitation can be set dynamically through I2C interface.
Overvoltage, overcurrent and overtemperature protections are included in the device.
A programmable watchdog improves the robustness and the safety of the complete
system.
Finally, the device is available in QFN24L 3 x 4 mm2.
STPD01主要特性:
• Input voltage range 6.0 V to 26.4 V
查看全文
