Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]TI DAC11001BµÍÔëÒô³¬µÍг²¨Ê§Õæ¸ßѹÊä³ö20λDAC½â¾ö·½°¸
¹Ø¼ü´Ê£º²âÊÔ²âÁ¿ Ò½ÁƵç×Ó ×¨ÒµÒôƵ·Å´óÆ÷ TI DAC11001B
ʱ¼ä£º2022-01-13 16:41:22       À´Ô´£ºÖеçÍø
TI¹«Ë¾µÄDAC11001BÊǸ߶Ⱦ«È·µÍÔëÒôµçѹÊä³öµ¥¶ËÊýģת»»Æ÷(DAC),¶ÔËùÓÐÊä³ö·¶Î§Ìṩ¼«ºÃµÄÏßÐÔ¶È.ÎÞ»º³åµÄµçѹÊä³öÌṩ¿ìËÙÉ趨ʱ¼ä(1 ¦Ìs)ºÍµÍÔëÒôÐÔÄÜ(7 nV/¡ÌHz),ʹµÃÆ÷¼þ·Ç³£ÊʺϵÍÔëÒô¿ìËÙ¿ØÖÆ»ØÂ·ºÍ²¨ÐβúÉúµÄÓ¦ÓÃ.DAC11001B¼¯³ÉÁËÓë´úÂëÎ޹صij¬µÍ¼â·å(1 nV-s)µÄÔöÇ¿¿¹¼â·åµç·,ʹµÃÇåÎú²¨ÐξßÓг¬µÍµÄ×Üг²¨Ê§Õæ(THD) (¨C118 dB at 20-kHz fOUT, 1-MHz fDAC). DAC11001B²ÉÓö๦ÄÜ4Ïß´®ÐнӿÚ,¹¤×÷ʱÖÓËÙÂʸߴï50MHz.¹¤×÷ζȨC40¡ãC µ½ +125¡ãC,²ÉÓÃ48Òý½ÅTQFP·â×°.Ö÷ÒªÓÃÔÚʵÑéÊÒºÍÏÖ³¡ÒDZí,·Ö¹â¼Æ,Ä£ÄâÊä³öÄ£¿é,µç³Ø²âÊÔ,°ëµ¼Ìå²âÊÔ,ÈÎÒⲨÐη¢ÉúÆ÷(AWG),MRI,XÉäÏßϵͳ,רҵÒôƵ·Å´óÆ÷(»ú¼ÜÐÍ).±¾ÎĽéÉÜÁËDAC11001BÖ÷ÒªÌØÐÔ, ¹¦ÄÜ¿òͼºÍ¶àÖÖÓ¦Óõç·,ÒÔ¼°ÆÀ¹ÀÄ£¿éBP-DAC11001 EVMÖ÷ÒªÌØÐÔ,¿òͼ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
The 20-bit DAC11001B is a highly accurate, lownoise,voltage-output, single-channel, digital-to-analogconverter (DAC). The DAC11001B is specifiedmonotonic by design, and offers excellent linearityacross all output ranges.
The unbuffered voltage output offers low noiseperformance (7 nV/¡ÌHz) in combination with a fastsettling time (1 ¦Ìs), making this device an excellentchoice for low-noise, fast control-loop, and waveformgenerationapplications. The DAC11001B integratesan enhanced deglitch circuit with code-independentultra-low glitch (1 nV-s) to enable clean waveformramps with ultra-low total harmonic distortion (THD).
The DAC11001B device incorporates a power-onreset(POR) circuit so that the DAC powers onwith known ..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
