关键词:Arm Cortex-M4 MCU 容性触摸 LCD控制器 RA4M1
时间:2020-05-21 13:12:16 来源:中电网
Renesas公司的RA4M1是采用高性能Arm® Cortex®-M4核的微控制器(MCU)系列产品,提供分段LCD控制器和容性触摸检测单元.MCU集成了多个软件和引脚兼容的Arm®32位核,提供低功耗,高性能Arm Cortex®-M4核,工作频率48MHz,集成了256KB闪存,32KB SRAM,分段LCD控制器(SLCDC),容性触摸检测单元(CTSU),USB 2.0全速模块(USBFS),14位ADC(ADC14)和12位DAC(DAC12),8位DAC(DAC8)x2,低功耗模拟比较器(ACMPLP)x2,运算放大器(OPAMP)x4以及温度传感器(TSN).具有加密AES128/256和GHASH以及真随机号码发生器(TRNG).工作温度-40℃ 到 +85℃和-40℃到 +105℃.中电网为您整理如下详细资料,主要用在密集的人机界面设计如容性触摸通路和分段LCD控制器.本文介绍了RA4M1主要特性,框图,以及评估板EK-RA4M1 v1主要特性,框图,电路图,材料清单和PCB设计图.
The Renesas RA4M1 group of micrcontrollers (MCUs) uses the high-performance Arm® Cortex®-M4 core and offers a segment LCD controller and a capacitive touch sensing unit input for intensive HMI designs. The RA4M1 MCU is built on a highly efficient low power process and is supported by an open and flexible ecosystem concept—the Flexible Software Package (FSP), built on FreeRTOS—and is expandable to use other RTOSes and middleware. The RA4M1 is suitable for applications where a large amount of capacitive touch channels and a segment LCD controller are required.
The MCU integrates multiple series of software- and pin-compatible Arm®-based 32-bit cores that share a common setof Renesas periph..
分享到:
