Silabs公司的Si52258/54是用于PCIe Gen1/2/3/4/5公共时钟和/或SRIS的业界最高性能和最低功耗汽车级的PCIe时钟发生器,所有时钟和PCIe Gen1/2/3/4/5公共时钟与单独基准架构指标兼容,硬件控制引脚可用来启动和禁止输出,以及启动和禁止扩展频谱用来降低EMI.Si52258/54具有内部终端的8/4输出,和PCIe Gen 1/2/3/4/5兼容,汽车级2工作温度–40 到 +105℃,内部100 Ω 或85 Ω电阻线路匹配,具有极好的抖动性能: Gen3/4为0.05 ps RMS, Gen5为0.025 ps RMS.三角扩展频谱用来降低EMI,可低至0.25%或0.5%,单独硬件控制引脚用来输出使能,扩展频谱使能,25MHz晶振输入或时钟输入,工作电压1.8V-3.3V,无铅RoHS-6兼容.主要用在信息娱乐设备, ADAS ECU,雷达传感器和激光雷达(LiDar)传感器.本文介绍了Si52258主要特性和特性列表,框图以及评估板Si52258-EVB主要特性,功能框图和主要特性,电路图,材料清单和PCB设计图.
The Si52258/54 are the industry’s highest performance and lowest power automotive grade PCI Express clock generators for PCIe Gen1/2/3/4/5 common clock and/or SRIS applications. The Si52258 and Si52254 source eight and four 100 MHz PCIe differential clock outputs, respectively. All clock outputs are compliant to PCIe Gen1/2/3/4/5 common clock and separate reference clock architecture specifications.
Hardware control pins are available for enabling and disabling the outputs, as well as spread spectrum enable/disable for EMI reduction.
For more information about PCI Express, Silicon Labs’ complete PCIe portfolio, applicationnotes, and design tools, including the Silicon Labs PCIe Clock Jitter Tool for PCI Expresscompliance, please visit the Silicon Labs PCI Express Learning Center.
Si52258主要特性:
• 8/4-outputs with internal termination
• PCIe Gen 1/2/3/4/5 compliant
• Automotive grade 2: –40 to +105℃
• Internal 100 Ω or 85 Ω line matching
• Excellent jitter performance
• 0.05 ps RMS (Gen3/4)
• 0.025 ps RMS (Gen5)
• Triangular spread spectrum for EMIreduction, down spread 0.25% or 0.5%
• Individual hardware control pins for OutputEnable, Spread Spectrum Enable
• Enable and Frequency Select
• 25 MHz crystal input or clock input
• 1.8–3.3 V power supply
• Pb-free, RoHS-6 compliant
Si52258应用:
• Infotainment
• ADAS ECU
• Radar Sensors
• LiDar Sensors
Si52258特性列表:
• PCIe Gen1/2/3/4/5 compliant
• Triangular spread spectrum for EMI reduction, down spread 0.25% or 0.5%
• Individual hardware control pins for Output Enable, Spread Spectrum Enable
图1.Si5225x系列框图
评估板Si52258-EVB
The Si52258-EVB is used for evaluating the eight output Si52258A-D01AM Automotive gradePCIe Reference Clock Generator. The Si52258A-D01AM device uses the on-board 25 MHz crystal as reference clock source and generates 8 copies of a 100 MHz HCSL format output clock compliant to PCIe Gen 1/2/3/4/5 common clock and separate reference clock specifications.
评估板Si52258-EVB主要特性:
• Powered from either USB port or external +5Vpower supply.
• On-board 25 MHz crystal reference.
• Programmable device core VDD supply foroperation at 3.3 V, 2.5 V, or 1.8 V.
• Programmable VDDO (output driver) suppliesallow each of the clock output banks to have itsown power supply voltage selectable from 3.3V, 2.5 V, or 1.8 V.
• SMA connectors for all output clocks.
• PCIe compliant spread spectrum enabled/disabled via on-board switch.
• Internal output termination switch selectable for100 Ω or 85 Ω operation.
• Output enable (OE) control switch per output.
• All output trace lengths matched to 10 inches.
• Loss of Signal (LOS) indication LED.
图2.评估板Si52258-EVB外形图
图3.评估板Si52258-EVB功能框图
图4.评估板Si52258-EVB DIP开关位置图
图5.评估板Si52258-EVB电路图(1)
图6.评估板Si52258-EVB电路图(2)
图7.评估板Si52258-EVB电路图(3)
图8.评估板Si52258-EVB电路图(4)
图9.评估板Si52258-EVB电路图(5)
图10.评估板Si52258-EVB PCB设计图(1)
图11.评估板Si52258-EVB PCB设计图(2)
图12.评估板Si52258-EVB PCB设计图(3)
图13.评估板Si52258-EVB PCB设计图(4)
图14.评估板Si52258-EVB PCB设计图(5)
图15.评估板Si52258-EVB PCB设计图(6)
图16.评估板Si52258-EVB PCB设计图(7)
图17.评估板Si52258-EVB PCB设计图(8)
图18.评估板Si52258-EVB PCB设计图(9)
图19.评估板Si52258-EVB PCB设计图(10)
图20.评估板Si52258-EVB PCB设计图(11)
图21.评估板Si52258-EVB PCB设计图(12)
图22.评估板Si52258-EVB PCB设计图(13)
图23.评估板Si52258-EVB PCB设计图(14)
评估板Si52258-EVB材料清单:
详情请见:
https://www.silabs.com/documents/public/data-sheets/si5225x-datasheet.pdf
和https://www.silabs.com/documents/public/user-guides/ug399-si52258-evb.pdfsi5225x-datasheet.pdf
分享到:
