[原创] Infineon IFX007T BLDC马达控制方案
关键词:马达控制 机器人 工业自动化 家用电器 医疗电子 IFX007T
时间:2019-07-16 11:00:34       来源:中电网
Infineon公司的IFX007T是集成了大电流半桥的马达驱动器,是工业和多用途NovalithIC™系列中一员,一个封装内包含有P沟高边MOSFET和N沟低边MOSFET以及集成的驱动器集成电路,它具有逻辑电平输入,带电流检测的诊断,转换速率调整,死区时间产生以及超温保护,欠压保护,过流保护和短路保护等特性,很容易和微控制器接口.通路电阻最大为12.8 mΩ @ 25℃ (typ.10.0 mΩ @ 25℃),高边电阻最大为6.5 mΩ @ 25℃ (typ.5.3 mΩ @ 25℃),低边电阻最大为6.3 mΩ @ 25℃ (typ. 4.7mΩ @ 25℃),限流电流最大为55A,工作电压高达40 V, RoHS兼容,满足JESD47I规范,主要用在自动化,家用电器,机器人和医疗电子以及电动工具,小型机器人,无人机,真空吸尘器,医用马达,医院病床,3D打印机,电风扇,电泵等.本文介绍了IFX007T主要特性,框图和应用电路,以及马达控制板主要特性,电路图,PCB设计图.
The IFX007T is an integrated high current half bridge for motor drive applications. It is part of the Industrial &Multi PurposeNovalithIC™ family containing one p-channel high-side MOSFET and one n-channel low-sideMOSFET with an integrated driver IC in one package. Due to the p-channel high-side switch the need for acharge pump is eliminated thus minimizing EMI. Interfacing to a microcontroller is made easy by theintegrated driver IC which features logic level inputs, diagnosis with current sense, slew rate adjustment, deadtime generation and protection against overtemperature, undervoltage, overcurrent and short circuit.
查看全文
