[原创] Cypress S6E2G系列FM4 32位MCU开发方案
关键词:Arm Cortex-M4 MCU 工业自动化 测试测量 S6E2G系列
时间:2019-02-15 11:01:52       作者:Cypress       来源:中电网
Cypress公司的S6E2G系列是32位Arm® Cortex®-M4F FM4微控制器,CPU工作频率高达180MHz,集成了1MB闪存,192KB SRAM,20x通信外设,33x数字外设和3x模拟外设,具有高性能和有竞争力的成本,设计用于工业自动化和测试测量.本文介绍了S6E2G系列主要特性和产品详细特性,框图,以及两种版本开发平台FM4-U120-9B560主要特性和电路图.
FM4-U120-9B560 - Arm® Cortex®-M4 MCU Starter Kit with USB and CMSIS-DAP S6E2G Series are FM4 devices with up to 180 MHz CPU, 1 MB flash, 192 KB SRAM, 20x communication peripherals, 33x digitalperipherals and 3x analog peripherals. They are designed for industrial automation and metering applications.
Devices in the S6E2G Series are highly integrated 32-bit microcontrollers with high performance and competitive cost. This series isbased on the Arm® Cortex®-M4F processor with on-chip flash memory and SRAM. The series has peripherals such as motor controltimers, A/D converters, and communications interfaces (USB, CAN, UART, CSIO (SPI), I2C, LIN).
S6E2G系列主要特性:
 32-bit Arm Cortex-M4F Core
 Up to 180 MHz frequency operation
 On-chip Memories
 Flash memory: Up to 1024 Kbytes
 SRAM memory:
• SRAM0: up to 128 Kbytes
• SRAM1: 32 Kbytes..
查看全文
