[原创] Avnet ZynqUltraScale+ MPSoC系列开发方案Ultra96
关键词:ARM Cortex-A53 MCU UltraScale MPSoC IoT (物联网)
时间:2018-12-10 10:56:34       作者:Avnet       来源:中电网
Avnet公司的ZynqUltraScale+ MPSoC系列开发板Ultra96是基于Xilinx® UltraScale™ MPSoC架构.单一器件集成了特性丰富的64位四核或双核ARM® Cortex™-A53和双核ARM Cortex-R5处理系统(PS)以及Xilinx可编逻辑(PL)UltraScale架构;此外还集成了片上存储器,多端口外接存储器接口,以及丰富的外设连接接口.处理单元的CPU频率高达1.5GHz,采用ARMv8-A架构,64位或32位工作模式,主要用在工业,IoT (物联网),嵌入式设计与开发和电子设计.本文介绍了Zynq® UltraScale+™ MPSoC系列主要特性以及开发板Ultra96主要特性,框图,电路图,材料清单和PCB设计图.
The Zynq® UltraScale+™ MPSoC family is based on the Xilinx® UltraScale™ MPSoC architecture. Thisfamily of products integrates a feature-rich 64-bit quad-core or dual-core ARM® Cortex™-A53 anddual-core ARM Cortex-R5 based processing system (PS) and Xilinx programmable logic (PL)UltraScalearchitecture in a single device. Also included are on-chip memory, multiport external memory interfaces,and a rich set of peripheral connectivity interfaces.
Zynq® UltraScale+™ MPSoC系列主要特性:
Processing System (PS)
ARM Cortex-A53 Based Application
Processing Unit (APU)
• Quad-core or dual-core
• CPU frequency: Up to 1.5GHz
• Extendable cache coherency
• ARMv8-A Architecture
o 64-bit or 32-bit operating modes..
查看全文
