[原创] Cypress PSoC 62系列MCU开发方案
关键词:ARM Cortex-M4F MCU ARMCortex M0+ CPU PSoC PSoC 62系列
时间:2018-11-29 11:25:46       作者:Cypress       来源:中电网
Cypress公司的PSoC 62系列MCU是可升级和可配置的平台架构,采用超低功耗40nm技术,组合了双核MCU(150-MHz Arm Cortex-M4F CPU和100-MHz Cortex M0+ CPU)和低功耗闪存(多达2MB)以及1MB SRAM,数字可编逻辑,高性能模数和数模转换器,低功耗比较器以及其标准通信和定时外设.器件可提供多达104 GPIO,工作电压1.7V-3.6V,主要用在可爱穿戴,智能家居,工业IoT,手持医疗设备等.本文介绍了PSoC 62系列主要特性,框图和时钟框图,以及PSoC 6 Wi-Fi BT原型套件CY8CPROTO-062-4343W主要特性,电路图,材料清单和PCB设计图与装配图.
PSoC® is a scalable and reconfigurable platform architecture for a family of programmable embedded system controllers with Arm®Cortex™ CPUs (single and multi-core). The PSoC 6 product family, based on an ultra low-power 40-nm platform, is a combination ofa dual-core microcontroller with low-power Flash technology and digital programmable logic, high-performance analog-to-digital anddigital-to-analog conversion, low-power comparators, and standard communication and timing peripherals.
PSoC 62系列主要特性:
32-bit Dual Core CPU Subsystem
■ 150-MHz Arm Cortex-M4F CPU with single-cycle multiply(Floating Point and Memory Protection Unit)
■ 100-MHz Cortex M0+ CPU with single-cycle multiply and MPU
■ User-selectable core logic operation at either 1.1 V or 0.9 V
■ Inter-processor communication supported in hardware..
查看全文
