[原创] NXP MC33GD3100单路IGBT栅极驱动器解决方案
关键词:汽车电子 IGBT MC33GD3100
时间:2018-11-23 16:53:21       作者:NXP       来源:中电网
nxp公司的MC33GD3100是高档单路IGBT栅极驱动器,集成了电流隔离和低开态电阻驱动晶体管,提供高充电和放电电流,低动态饱和电压,轨到轨电压控制,通过INTB引脚和SPI接口能管理严重故障并报告故障与状态.和安全等级ASIL D ISO 26262规范兼容,功率范围大于125kW,满足AEC-Q100 grade 1规范,主要用在汽车电子.本文介绍了MC33GD3100主要特性和优势,框图,简化应用框图以及半桥评估板FRDM-GD3100EVM主要特性和电路图.
The MC33GD3100 is an advanced single channel gate driver for IGBTs. Integrated Galvanic isolation and low on-resistance drive transistors provide high charging and discharging current, low dynamic saturation voltage and rail-to-rail gate voltage control. Current and temperature sense minimizes IGBT stress during faults. Accurate and configurable under voltage lockout (UVLO) provides protection while ensuring sufficient gate drive voltage headroom.
The MC33GD3100 autonomously manages severe faults and reports faults and status via INTB pin and an SPI interface. It is capable of directly driving gates of most IGBTs. Self test, control and protection functions are included for design of high reliability systems (ASIL C/D). It meets the stringent requirements of automotive applications and is fully AEC-Q100 grade 1 qualified.
MC33GD3100主要特性和优势:
• Compatible with current sense and temp sense IGBTs
• Fast short-circuit protection for IGBTs with current sense feedback
• Compliant with ASIL D ISO 26262 functional safety requirements
• SPI interface for safety monitoring, programmability and flexibility
• Integrated Galvanic signal isolation
• Integrated gate drive power stage capable of 10 A peak source and sink
• Interrupt pin for fast response to faults
• Compatible with negative gate supply
• Compatible with 200 V to 1700 V IGBTs, power range > 125 kW
• AEC-Q100 grade 1 qualified
图1.MC33GD3100框图
图2. MC33GD3100简化应用框图
半桥评估板FRDM-GD3100EVM
The FRDM-GD3100EVM is a half-bridge evaluation kit populated with two MC33GD3100 single channel IGBT gate drive devices on a half-bridge evaluation board. The kit includes the Freedom KL25Z microcontroller hardware for interfacing a PC installed with SPIGen software for communication to the SPI registers on the MC33GD3100 gate drive devices in either daisy chain or standalone configuration.
The GD3100 translator board is used to translate 3.3 V signals to 5.0 V signals between the MCU and MC33GD3100 gate drivers. The evaluation kit can be connected to a single phase of a Fuji M653 or M6+ IGBT module for half-bridge evaluations and applications development.
半桥评估板FRDM-GD3100EVM主要特性:
Capability to connect to Fuji M653 or M6+ IGBT modules for half-bridge evaluations
Daisy Chain SPI communication capable
Easy access to power, ground, and signal test points
Easy to install and use SPIGen GUI for interfacing via SPI through PC. Software includes Double Pulse and Short Circuit testing capability.
FRDM-GD3100EVM: Half-bridge evaluation board for GD3100
图3.半桥评估板FRDM-GD3100EVM外形图
半桥评估板FRDM-GD3100EVM包括:
• Complete assembly of KITGD3100 connected to FRDM-KL25Z
• 3.3 V to 5.0 V translator board
• Cable, USB type A male/type mini B male 3 ft
• Quick start guide
图4.半桥评估板FRDM-GD3100EVM电路图(1)
图5.半桥评估板FRDM-GD3100EVM电路图(2)
详情请见:
https://www.nxp.com/docs/en/data-sheet/MC33GD3100_SDS.pdf
https://www.nxp.com/docs/en/user-guide/UM11108.pdf
MC33GD3100_SDS.pdf
UM11108.pdf
