[原创] ADI ADuCM4050超低功耗带功率管理的ARM MCU开发方案
关键词:ARM Cortex-M4F MCU 物联网(IoT) 可穿戴 智能农业 智能城市
时间:2018-09-21 11:33:41       作者:ADI       来源:中电网
ADI公司的ADuCM4050是超低功耗集成了带功率管理的基于ARM® Cortex®-M4F处理器的微控制器(MCU),同时集成了数字外设,嵌入SRAM和嵌入闪存和提供时钟,重置和功率管理功能的模拟子系统以及模数转换器(ADC)子系统.MCU工作频率高达52MHz,主要用在物联网(IoT),智能农业,智能建筑,智能测量,智能城市,智能机器和传感器网络,可穿戴设备,健身和医疗等.本文介绍了ADuCM4050产品亮点和主要特性,框图和几种应用电路,开发平台EV-COG-AD4050主要特性和优势以及电路图.
The ADuCM4050 microcontroller unit (MCU) is an ultra low power integrated microcontroller system with integrated power management for processing, control, and connectivity. The MCU system is based on the ARM® Cortex®-M4F processor. The MCU also has a collection of digital peripherals, embedded static random access memory (SRAM) and embedded flash memory, and an analog subsystem that provides clocking, reset, and power management capabilities in addition to an analog-to-digital converter (ADC) subsystem.
This data sheet describes the ARM Cortex-M4F core and memory architecture used on the ADuCM4050 MCU. It does not provide detailed programming information about the ARM processor.
查看全文
