[原创] Maxim MAX32631超低功耗ARM MCU可穿戴解决方案
关键词:Arm Cortex-M4 MCU 可穿戴设备 物联网(IoT) 手持医疗电子
时间:2018-09-03 10:02:39       作者:Maxim       来源:中电网
Maxim公司的MAX32631是用于可穿戴设备的超低功耗高性能具有FPU的ARM MCU,提供容易使用的超低功耗高效信号处理功能,其灵活的功率模式,智能外设管理单元(PMU),动态时钟门和固件控制的功率门优化功率,并提供多个SPI,UART,I2C,1-Wire®主和USB接口,器件四输入可选基准的10位ADC能监测外接传感器.MCU工作频率96MHz,集成了2MB闪存,512KB SRAM,8KB指令缓存,1.2V CPU核电压,1.8-3.3V I/O,主要用在运动手表,健身监视器,可穿戴医疗贴片,手持医疗设备和传感器集线器.本文介绍了MAX32631主要优势和特性,功能框图和时钟方案,以及评估板MAX32630 EVK主要优势和特性,框图,电路图,材料清单和PCB设计图.
DARWIN is a new breed of low-power microcontrollers built to thrive in the rapidly evolving Internet of Things (IoT). They are smart, with the biggest memories in their class and a massively scalable memory architecture. They run forever, thanks to wearable-grade power technology. They are also tough enough to withstand the most advanced cyberattacks. DARWIN microcontrollers are designed to run any application imaginable—in places where you wouldn’t dream of sending other microcontrollers.
查看全文
