[原创] Infineon IFCM15P60GDCIPOS模块三相马达控制方案
关键词:电源管理 马达控制 CIPOS模块 IFCM15P60GD
时间:2018-08-21 10:28:00       作者:Infineon       来源:中电网
Infineon公司的IFCM15P60GD是CIPOS™模块系列产品,集成了各种功率和控制元件,从而增加了可靠性,优化PCB尺寸和系统成本.它采用单相PFC以可变速度来控制三相AC马达和永磁电机如空调和低功率马达,主要用在家用兵电器和低功率马达驱动.本文介绍了IFCM15P60GD主要特性,应用电路以及评估板EVAL-M3-CM615PN主要特性和指标,框图和电路图,材料清单和PCB设计图.
The CIPOS™ module family offers the chance for integrating various power and control components to increase reliability, optimize PCB size and system costs.
It is designed to control three phase AC motors and permanent magnet motors with single phase PFC in variable speed drives for applications like an air conditioning and low power motor drives. The package concept is specially adapted to power applications, which need good thermal conduction and electrical isolation, but also EMI-save control and overload protection.
TRENCHSTOP™ IGBT3 and anti-parallel diodes are combined with an optimized SOI gate driver for excellent electrical performance.
System Configuration
 3 half bridges with TRENCHSTOP™ IGBT3 and anti parallel diodes
 3ɸ SOI gate driver
 Single phase PFC with TRENCHSTOP™ 5 and Rapid switching emitter controlled diode
 Thermistor ..
查看全文
