[原创] Renesas ISL68300单输出数字PWM控制器解决方案
关键词:电源管理 DC/DC转换器 ISL68300
时间:2018-08-16 10:46:55       作者:Renesas       来源:中电网
Renesas公司的ISL68300是集成了驱动器和PMBus可升级单输出数字PWM控制器,特别适合和分立的MOSFET使用,完全实现了数字ChargeMode™控制调制方案,获得业界一流性能和容易使用.ChargeMode控制提供稳定控制回路,能响应在单个周期内负载瞬变,从而大大降低了对输出电容的要求.输入电压范围4.75V-16V或4.5V-5.5V,输出电压范围0.45V-5.5V,输出电压精度0.5%,开关频率范围200kHz 到1.0MHz,主要用在服务器和存储设备,通信和数据通信设备,以及如FPGA,ASIC,DSP和存储器电源.本文介绍了ISL68300主要特性,框图,几种应用电路,以及评估板ISL68300EVAL2Z主要特性和指标,电路图,材料清单和PCB设计图.
The ISL68300 is a PMBus compliant, single-phasedigital DC/DC controller optimized for use with discreteMOSFETs.
The ISL68300 implements the Renesas fully digitalChargeMode™ control modulation scheme, allowing itto achieve both industry leading performance and ease ofuse. ChargeMode control provides an inherently stablecontrol loop that can respond to load transients in a singleswitching cycle, significantly decreasing output capacitorrequirements.
A dedicated current share bus allows for paralleling up toeight devices in a current share configuration, allowingsupport for a wide range of load currents.
查看全文
