[原创] On Semi FAN65005A高性能65V 8A PWM降压电源解决方案
关键词:电源管理 DC/DC转换器 FAN65005A
时间:2018-07-12 10:59:53       作者:On Semi       来源:中电网
On Semi公司的FAN65005A是高性能65V/8A电压模式同步PWM降压稳压器,集成了高边和低边功率MOSFET,支持电压从4.5V到65V,处理连续电流高达8A.器件还包括高性能PowerTrenchR MOSFET,控制器和驱动器,0.67%精度基准电压0.6V,开关频率从100kHz到1MHz可编程,高性能6 mm x 6 mm PQFN封装,主要用在高压POL模块,通信基站电源,网络计算,电池管理系统和USB-PD以及工业自动化,电动工具和 (赌具).本文介绍了FAN65005A主要特性,应用电路以及65V/8A电压模式PWM降压稳压器评估板FAN65005A-GEVB主要特性和指标,电路图,材料清单和PCB设计图.
FAN65005A is a wide VIN highly efficient synchronous buckregulator, with integrated high side and low side power MOSFETs.
The device incorporates a fixed frequency voltage mode PWMcontroller supporting a wide voltage range from 4.5 V to 65 V and canhandle continuous currents up to 8 A.
FAN65005A includes a 0.67% accurate reference voltage to achievetight regulation. The switching frequency can be programmed from100 kHz to 1 MHz. To improve efficiency at light load condition, thedevice can be set to discontinuous conduction mode with pulseskipping operation.
FAN65005A has dual LDOs to minimize power loss and integratedcurrent sense circuit that provides cycle−by−cycle current limiting.
查看全文
