[原创] Microchip PIC18F47Q10低功耗MCU解决方案
关键词:工业控制 汽车电子 物联网(IoT) PIC18F47Q10
时间:2018-07-09 10:14:25       作者:Microchip       来源:中电网
Microchip公司的PIC18F47Q10是低功耗微控制器(MCU),集成了智能模拟可配置外设和5V工作条件以增强噪音免疫度,内核采用C编译器优化RISC架构,时钟输入DC-64MHz,指令周期最小为62.5ns,可编2级中断优先权,31级深度硬件堆栈,工作电压1.8V 到5.5V,主要用在工业控制,汽车电子,物联网(IoT),和触摸检测和消费类电子.本文介绍了PIC18F2x/4xQ10系列主要特性,以及Explorer 8开发板(DM160228)主要特性和电路图.
PIC18F2x/4xQ10 microcontrollers feature Analog, Core Independent, and Communication Peripherals fora wide range of general purpose and low-power applications. These 28/40/44 -pin devices are equippedwith a 10-bit ADC with Computation (ADC2) automating Capacitive Voltage Divider (CVD) techniques foradvanced touch sensing, averaging, filtering, oversampling and performing automatic thresholdcomparisons. They also offer a set of Core Independent Peripherals such as Complementary WaveformGenerator (CWG), Windowed Watchdog Timer (WWDT), Cyclic Redundancy Check (CRC)/MemoryScan, Zero-Cross Detect (ZCD), Configurable Logic Cell (CLC), and Peripheral Pin Select (PPS),providing for increased design flexibility and lower system cost.
PIC18F2x/4xQ10系列主要特性:
核特性:
• C Compiler Optimized RISC Architecture
• Operating Speed:
– DC – 64 MHz clock input over the full VDD range..
查看全文
