[原创] ST STEVAL-GLA001V1家用电器1kW AC开关控制方案
关键词:消费类电子 家用电器 STEVAL-GLA001V1
时间:2018-03-01 11:01:09       作者:ST       来源:中电网
ST公司的STEVAL-GLA001V1是采用可控硅(Triac)和交流(AC)开关来替代继电器的家用电器开发平台,能绝缘控制三个高达1kW的AC负载,具有宽输入电压范围,低待机损耗,IEC61000-4-4鲁棒和两个低压电源.主要用在微控制器和主电压需要隔离的家用电器如洗衣机,洗碗机,微波炉,灶具,烤箱,豆浆机,打印机,空调,冰箱和热水器和加热器.本文介绍了评估板STEVAL-GLA001V1主要特性,框图,电路图,材料清单以及PCB顶层丝印图.
The STEVAL-GLA001V1 evaluation board is designed to help you develop applications with insulated control of three AC loadsup to 1 kW (230 Vrms) using Triacs and AC switches instead of relays.
To control the STEVAL-GLA001V1 evaluation board, you can use a NUCLEO-F030R8 development board which allows threeAC switch control modes for load control: continuous or pulse gate current, a timer option, and phase control.
Once you have installed the relevant firmware (available free on the STEVAL-GLA001V1 web page) on the NUCLEO-F030R8development board, you can start adjusting the main parameters through a common serial interface like HyperTerminal.
The STEVAL-GLA001V1 evaluation board features a wide input voltage range, low standby power losses, IEC61000-4-4 robustnessand two low voltage power supplies.The targeted applications are residential appliances requiring insulation between microcontroller and mains voltage, such aswashing machines and dish washers, micro-wave ovens, cookers, ovens, soya-milk makers, printers, air-conditioners, fridges,water-heaters and heaters.
图1.评估板STEVAL-GLA001V1外形图
图2.IEC61000-4-4测试评估板STEVAL-GLA001V1连接图
评估板STEVAL-GLA001V1主要特性:
The STEVAL-GLA001V1 evaluation board features the following main components:
• AC switches (X101, X102 and X103)
• A flyback power converter providing:
– VCC_AC: non regulated output and referenced to mains voltage (VCC_AC positive regardingGND_AC).
◦ used to control the three AC switches.
◦maximum output current: 150 mA
– 5VDC: 5 V positive output, referenced to GND, insulated regarding mains voltage.
◦ supplies the LEDs and all other electronic parts if VDD selector is set to 5V position
◦maximum output current: 500 mA for all the secondary side (5 V, 3.3 V and VDD mixed)
– 3.3VDC: 3.3 V positive output, referenced to GND, insulated regarding mains voltage.
◦ supplies all other electronic parts if VDD selector is set to 3.3 V position.
– VDD: used to select whether the external microcontroller is supplied with 5 V or 3.3 V (default).
图3.评估板STEVAL-GLA001V1框图
图4.评估板STEVAL-GLA001V1 AC输入电路图
图5.评估板STEVAL-GLA001V1 ZVS检测电路图
图6.评估板STEVAL-GLA001V1Triac栅极控制图
图7.评估板STEVAL-GLA001V1Triac/ACS连接图
图8.评估板STEVAL-GLA001V1电源电路图
图9.评估板STEVAL-GLA001V1 LED指示器
图10.评估板STEVAL-GLA001V1指令/参数按扭
图11.评估板STEVAL-GLA001V1模式选择开关
图12.评估板STEVAL-GLA001V1用户板连接器
图13.评估板STEVAL-GLA001V1 34引脚ST板连接器
评估板STEVAL-GLA001V1材料清单:
图14.评估板STEVAL-GLA001V1 PCB顶层丝印图
详情请见:
http://www.st.com/content/ccc/resource/technical/document/user_manual/group0/cb/8b
/ed/0c/f5/82/49/44/DM00445236/files/DM00445236.pdf/jcr:content/translations/en.DM00445236.pdf
en.DM00445236.pdf
