[原创] Marvell ARMADA 8040系统级芯片(SoC)解决方案
关键词:ARM Cortex-A72 MCU 有线网络 网关 ARMADA 8040
时间:2018-02-28 10:40:10       作者:Marvell       来源:中电网
Marvell公司的ARMADA® 8040 (88F8040)是采用最新的ARMv8 CPU技术的完整的系统级芯片(SoC)解决方案,非常适合用在各种的SoHo, SMB以及企业经典应用.本文介绍了ARMADA® 8040主要特性和优势,框图,以及ARMADA® 8040开发板MACCHIATOBin主要特性和系统指标,框图和电路图.
The Marvell® ARMADA® 8040 (88F8040) is a complete system-on-chip (SoC) solution based on the latest ARMv8 high-performance CPU technology, ideally suited for a wide range of SoHo, SMB and Enterprise class applications. The first two products of the ARMADA® 8K Family, the Armada® 8040 and the Armada® 8020 include, respectively, a quad-core and a dual-core ARM Cortex-A72, bringing a high level of performance, integration, and efficiency, and delivers an optimal Performance-per-Watt in the embedded markets. 88F8040 built as part of Marvell’s MoChi family of products. As the MCi interface is essentially transparent to the driver, all the connected MCi will appear to the driver as though it is an integrated function in the 88F8040 itself, enabling a Virtual System-on-Chip (vSoC). The 88F8040 also supports standard high speed DDR4 interface in 32b bus widths, with optional ECC function.
ARMADA® 8040主要特性和优势:
ARMADA® 8040目标应用:..
查看全文
