[原创] TI TIDA-01471 PLC模拟输入IEPE震动传感器接口参考设计
关键词:数据采集 测量系统 PLC IEPE震动传感器 信号调理 TIDA-01471
时间:2018-01-26 10:35:28       作者:TI       来源:中电网
TI公司的TIDA-01471是PLC模拟输入综合压电(IEPE)震动传感器接口参考设计,具有单路IEPE传感器模拟输入,24位转换效率,20kHz信号带宽,可编数据速率265 kSPS到 32 kSPS,可调增益-12dB到18dB,可编程激励电流2-20mA,±10-V AC输入,250-kΩ输入阻抗,工作温度–40℃ - 85℃,主要用在PLC,DCS模拟和混合输入模块,模拟信号调理/发送器,震动开关,数据采集和测量系统.本文介绍了参考设计TIDA-01471主要特性和指标,框图和测试建立图,电路图,材料清单和PCB设计图.
Industrial vibration sensing is a crucial process incondition monitoring, which is necessary for predictivemaintenance. An integrated electronic piezoelectric(IEPE) sensor is the most common vibration sensorused in the industrial environment. The TIDA-01471design is a full analog front end for the IEPE sensorinterface and demonstrates how to achieve flexiblehigh-resolution, high-speed conversion with low-powerand small-footprint implementation.
查看全文
