[原创] Infineon1200V CoolSiC MOSFET评估方案
关键词:电源管理 CoolSiC MOSFET IGBT
时间:2018-01-25 10:18:35       作者:Infineon       来源:中电网
infineon公司的评估板EVAL-IGBT-1200V-TO247PLUS是用来评估TO-247 3引脚/4引脚封装的1200V CoolSiC™ MOSFET的实验室产品,具有两种工作模式,用来研究开关特性和测量不同条件下IGBT和二极管损耗,也可以工作在连续模式,也可配置成降压或升压DC/DC转换器.本文介绍了评估板EVAL-IGBT-1200V-TO247PLUS主要特性和优势,框图,电路图和材料清单以及PCB设计图.
This application note is a user guide for the 1200V CoolSiC™ MOSFET in TO-247 3pin/4pin evaluation board. It explains the board’s hardware and provides detailed instructions on how to use it for addressing various measurement tasks. Finally, practical examples demonstrate the performance of the MOSFET.
The board described is an evaluation board dedicated for laboratory environment only. It operates at high voltages and must only be operated by qualified and skilled personnel familiar with all applicable safety standards.
The evaluation board is delivered together with spare parts and complete ocumentation in an environmentally friendly carton box as illustrated in Figure 1. As depicted, the carton box contains:
 Evaluation board EVAL-COOLSIC-MOSFET-1200V-TO247-4 (172mm x 133mm x 72mm; LxWxH)
 1200V CoolSiC™ MOSFETs IMW120R045M1 and IMZ120R045M1
 1ED Compact isolated gate-driver ICs 1EDI20H12AH in a 300mil wide-body package
 USB flash drive containing all related application notes and data sheets
 Wire-to-board plugs for connecting the evaluation board to sources and loads
图1.评估板EVAL-IGBT-1200V-TO247PLUS外形图
Evaluation board EVAL-IGBT-1200V-TO247PLUS has been developed to be a simple but accurate universal test platform for 1200V IGBTs in all TO-247 package variants, i.e. standard TO-247 as well as TO-247PLUS packages with three as well as four leads.
评估板EVAL-IGBT-1200V-TO247PLUS主要特性:
The board allows evaluating the advantages provided by the larger lead frame area of the TO-247PLUS package as well as the performance improvement given by the Kelvin emitter connection of the TO-247PLUS 4pin package.
评估板EVAL-IGBT-1200V-TO247PLUS优势:
Two different modes of operation can be realized with this board. It can be used to investigate switching behavior and measure IGBT and diode losses at different test conditions. Also the board can be used in continuous operation. From the basic phase-leg topology, it is possible to configure it as a step-down or step-up DC-DC converter.
图2.评估板EVAL-IGBT-1200V-TO247PLUS电路图概述
图3.评估板EVAL-IGBT-1200V-TO247PLUS电路图:电源和驱动电路
图4.评估板EVAL-IGBT-1200V-TO247PLUS电路图:辅助电源和LED指示器
评估板EVAL-IGBT-1200V-TO247PLUS材料清单:
图5.评估板EVAL-IGBT-1200V-TO247PLUS PCB设计图(1):层1(顶层)
图6.评估板EVAL-IGBT-1200V-TO247PLUS PCB设计图(2):层2
图7.评估板EVAL-IGBT-1200V-TO247PLUS PCB设计图(3):层3
图8.评估板EVAL-IGBT-1200V-TO247PLUS PCB设计图(4):层4(底层)
详情请见:
https://www.infineon.com/dgdl/Infineon-EVAL-COOLSIC-MOSFET-1200V-TO247-4-AN-v01_00-EN.pdf?fileId=5546d4625fe36784015fee54157460d8
