[原创] ADI ADP1074隔离式DC-DC同步电源设计方案
关键词:电源管理 DC/DC转换器 iCoupler ADP1074
时间:2017-11-07 11:07:04       作者:ADI       来源:中电网
ADI公司的ADP1074是集成有源钳位和iCoupler®的隔离式同步正向控制器,集成了ADI公司的专有iCouplers,在原边和副边均集成了隔离器和MOSFET驱动器,从而降低了系统设计复杂性,成本和元器件数量,并提高了系统的整体可靠性.此外还具有输入电流保护,欠压闭锁(UVLO),带可调迟滞功能的精密使能和过温保护(OTP)等特性,主要用在隔离式DC/DC电源转换,中间总线电压生成,电信和工业,基站和天线RF功率,小型蜂窝,POE供电设备,企业交换机/路由器,核心/边缘/城域/光学路由以及电源模块.本文介绍了ADP1074主要特性,框图,多种应用电路以及评估板ADP1074-EVALZ主要特性,电路图,材料清单和PCB设计图.
The ADP1074 is a current mode, fixed frequency, active clamp, synchronous forward controller designed for isolated dc to dc power supplies. Analog Devices proprietary iCouplers® are integrated in the ADP1074 to eliminate the bulky signal trans-formers and optocouplers that transmit signals over the isolation boundary. Integrating the iCouplers reduces system design complexity, cost, and component count and improves overall system reliability. With the integrated isolators and metal-oxide semiconductor field effect transistor (MOSFET) drivers on both the primary and the secondary side, the ADP1074 offers a compact system level design and yields a higher efficiency than a non-synchronous forward converter at heavy loads.
The primary side pins provide functions for programming the switching frequency, maximum duty cycle, external frequency synchronization, and slope compensation. The secondary side pins provide functions for differential output voltage sensing, overvoltage, power good, tracking, and programmable light load mode setting.
The feedback signal and timing of synchronous rectifier pulse-width modulations (PWMs) are transmitted from primary to secondary or from secondary to primary sides through the iCouplers using a proprietary transmission scheme.
The ADP1074 also offers features such as input current protection, undervoltage lockout (UVLO), precision enable with adjustable hysteresis, overtemperature protection (OTP), and power saving light load mode (LLM).
ADP1074主要特性:
Current mode controller for active clamp forward topology
Integrated 5 kV rated dielectric isolation voltage with Analog Devices, Inc., patented iCoupler technology
Wide voltage supply range
Primary VIN: up to 60 V
Secondary VDD2: up to 36 V
Integrated 1 A primary side MOSFET driver for power switch and active clamp reset switch
Integrated 1 A secondary side MOSFET drivers for synchronous rectification
Integrated error amplifier and <1% accurate reference voltage
Programmable slope compensation
Programmable frequency range: 50 kHz to 600 kHz typical
Frequency synchronization
Programmable maximum duty cycle limit
Programmable soft start
Smooth soft start from precharged load
Programmable dead time
Power saving light load mode using MODE pin
Protection features such as short circuit, output overvoltage, and overtemperature protection
Cycle-by-cycle input overcurrent protection
Precision enable UVLO with hysteresis
PGOOD pin for system flagging
Tracking function from secondary side
Remote (secondary side) shutdown/reset function
Safety and regulatory approvals (pending)
UL recognition
5000 V rms for 1 minute per UL 1577
CSA component acceptance notice 5A
VDE certificate of conformity
DIN V VDE V 0884-10 (VDE V 0884-10):2006-12
VIORM = 849 V peak
CQC certification per GB4943.1-2011
Available in 24-lead SOIC_W package
ADP1074应用:
Isolated dc-to-dc power conversion
Intermediate bus voltage generation
Telecom, industrial
Base station and antenna RF power
Small cell
PoE powered device
Enterprise switches/routers
Core/edge/metro/optical routing
Power modules
图1.ADP1074详细框图
图2.ADP1074有源钳位正向拓扑应用电路图
图3.ADP1074带起动电路和偏压绕组的有源钳位正向拓扑应用电路图
图4.ADP1074有源钳位反激拓扑应用电路图
评估板ADP1074-EVALZ
The ADP1074-EVALZ evaluation board allows users to evaluate the ADP1074 in a power supply application.
The evaluation board can deliver a rated current of 6 A in steady state and 8 A peak that is thermally limited for an input voltage range of 36 V dc to 60 V.
Multiple test points allow easy access to all critical nodes and pins.
Full data on the ADP1074 is available in the ADP1074 data sheet, which should be consulted in conjunction with this user guide when using the evaluation board.
评估板ADP1074-EVALZ主要特性:
Fully supported evaluation kit for the ADP1074 active clamp forward topology
12.1 V output voltage (VDC)
6 A steady state, 8 A peak
Programmable light load mode
Integrated driver for primary side and secondary side synchronous rectifier
External reference signal tracking
Precision enabled undervolatge lockout (UVLO) with hysteresis
Short circuit, output overvoltage, cycle by cycle input overcurrent, and over temperature protection
Soft start and soft stop functionality
图5.评估板ADP1074-EVALZ外形图
图6.评估板ADP1074-EVALZ电路图
评估板ADP1074-EVALZ材料清单:
图7.评估板ADP1074-EVALZ PCB尺寸图
图8.评估板ADP1074-EVALZ PCB顶层丝印图
图9.评估板ADP1074-EVALZ PCB底层丝印图
图10.评估板ADP1074-EVALZ PCB顶层布局图
图11.评估板ADP1074-EVALZ PCB层2布局图
图12.评估板ADP1074-EVALZ PCB层3布局图
图13.评估板ADP1074-EVALZ PCB层4布局图
详情请见:
http://www.analog.com/media/en/technical-documentation/data-sheets/ADP1074.pdf
http://www.analog.com/media/en/technical-documentation/user-guides/ADP1074-EVALZ-UG-1115.pdf
ADP1074.pdf
