[原创] MicrosemiPolarFire第五代非易失FPGA系列开发方案
关键词:PolarFire FPGA 通信技术 工业应用 航空航天
时间:2017-10-26 10:18:52       作者:Microsemi       来源:中电网
Microsemi公司的PolarFire FPGA是第五代非易失FPGA器件,采用最新的28nm非易失工艺技术,具有中等密度和最低功耗,集成了最低功耗的FPGA架构,最低功耗的12.7Gbps收发器,内置低功耗双路PCI Express Gen2 (EP/RP),以及可选择数据安全器件和集成低功耗加密协处理器.多达481K逻辑单元,工作电压1.0V-1.05V,工作温度商用(0℃- 100℃),工业用(-40℃ - 100℃)主要用在通信,工业,航空航天和国防市场.本文介绍了PolarFire FPGA主要特性,低功耗特性,可靠特性和安全特性,框图,以及PolarFire FPGA评估板硬件特性,框图,电路图和元件表以及PCB元件布局图.
PolarFire™ FPGAs are the fifth-generation family of non-volatile FPGA devices from Microsemi, built onstate-of-the-art 28nm non-volatile process technology. Cost-optimized PolarFire FPGAs deliver thelowest power at mid-range densities. PolarFire FPGAs lower the cost of mid-range FPGAs by integratingthe industry’s lowest power FPGA fabric, lowest power 12.7 Gbps transceiver lane, built-in low powerdual PCI Express Gen2 (EP/RP), and, on select data security (S) devices, an integrated low-power cryptoco-processor. PolarFire FPGAs can operate at 1.0 V and 1.05 V, offering the end user the ability to tradeoff power and performance to match the application requirements.This document describes the features of PolarFire FPGA extended commercial (0℃ to 100℃) andindustrial (–40℃ to 100℃) device offerings.
PolarFire FPGA主要特性:
查看全文
