[原创] TI 2kW不间断电源(UPS)双向转换器参考设计TIDA-00951
关键词:电源管理 DC/DC转换器 不间断电源(UPS)
时间:2017-07-07 11:03:01       作者:TI        来源:中电网
TI公司的TIDA-00951是2kW 48V-400V效率大于93%的绝缘双向DC/DC转换器参考设计,数字控制,工作范围从36V-60V电池和300-400V DC总线,内置DC总线过流和过压以及电池过流等保护.隔离的CAN,I2C和蔼RS-485通信接口,主要用在服务器PSU和通信整流器,不间断电源(UPS),工业电源,电池充电器和能量存储系统.本文介绍了UPS系统架构图,2kW UPS参考设计TIDA-00951主要特性和指标,框图,电路图,材料清单和PCB设计图.
The TIDA-00951 design provides a reference solutionfor a 2-kW isolated bidirectional DC-DC convertercapable of power transfer between a 400-V DC busand a 12- to 14-cell Lithium battery pack for use inUPS, battery backup and power storage applications.
This TI Design works as a >93% efficient, current fed,active clamped boost converter with ZVS in thebackup mode and voltage fed full-bridge batter chargerwith >93% efficiency in the charging mode. This TIDesign has built-in protection for DC bus overcurrentand overvoltage and battery overcurrent.
2kW UPS参考设计TIDA-00951主要特性:
• Digitally Controlled Isolated Bidirectional DC-DCConverter
• Operates as Active Clamped Full Bridge BoostConverter With ZVS For All Low-Voltage Switchesat High Loads
• Operates as Active Clamped Voltage Fed BuckConverter With Synchronous Rectification toImprove Efficiency When Charging Battery
• Wide Operating Range From 36- to 60-V Batteryand 300- to 400-V DC Bus
• Cost Optimized Design Using 100-V FET on Low-Voltage Side, Eliminates Requirement forParalleling Multiple FETs up to 2 kW
• Built-in Cold Start Procedure and Fast ModeTransfer (< 100 μS) From Battery Charger toBackup Power Supply
• Onboard Isolated Communication Interface forCAN, I2C, and RS-485
2kW UPS参考设计TIDA-00951应用:
• Server PSUs and Telecom Rectifiers
• Uninterruptible Power Supplies (UPS)
• Industrial Power Supplies
• Battery Chargers
• Energy Storage Systems
图1.2kW UPS参考设计TIDA-00951外形图
2kW UPS参考设计TIDA-00951主要指标:
图2.典型UPS系统架构图
图3. 2kW 绝缘双向DC/DC转换器框图
图4.2kW UPS参考设计TIDA-00951电路图(1)
图5.2kW UPS参考设计TIDA-00951电路图(2)
图6.2kW UPS参考设计TIDA-00951电路图(3)
2kW UPS参考设计TIDA-00951材料清单:
图7.2kW UPS参考设计TIDA-00951 PCB设计图(1)
图8.2kW UPS参考设计TIDA-00951 PCB设计图(2)
图9.2kW UPS参考设计TIDA-00951 PCB设计图(3)
图10.2kW UPS参考设计TIDA-00951 PCB设计图(4)
图11.2kW UPS参考设计TIDA-00951 PCB设计图(5)
图12.2kW UPS参考设计TIDA-00951 PCB设计图(6)
图13.2kW UPS参考设计TIDA-00951 PCB设计图(7)
详情请见:
http://www.ti.com/lit/ug/tidud04/tidud04.pdf
https://www.ti.com/seclit/df/tidrr65/tidrr65.pdf
tidrr65.pdf
tidrr66.pdf
tidrr68.pdf
tidud04.pdf
