[原创] Microsemi PolarFire FPGA系列开发方案
关键词:PolarFire FPGA 物联网(IoT) 工业自动化 通信设备 有线接入网
时间:2017-07-05 11:21:46       作者:Microsemi       来源:中电网
Microsemi公司的PolarFire FPGA系列具有最低功耗最佳成本的中等规模的FPGA,逻辑单元(LE)从100K到500K,12.7G 收发器, 1.6 Gbps I/O,比同类产品的功耗低50%以上.主要用在物联网(IoT),工业自动化,通信设备,有线接入网,蜂窝基础设备,国防和航空通信领域.本文介绍了PolarFire FPGA系列主要特性,低功耗特性,可靠性和安全特性,框图,以及评估板MPF300-EVAL-KIT-ES主要特性,框图和电路图.
PolarFire™ FPGAs are the fifth-generation family of non-volatile FPGA devices from Microsemi, built on state-of-the-art 28nm non-volatile process technology. Cost-optimized PolarFire FPGAs deliver the lowest power at mid-range densities. PolarFire FPGAs lower the cost of mid-range FPGAs by integrating the industry’s lowest power FPGA fabric, lowest power 12.7 Gbps transceiver lane, built-in low power dual PCI Express Gen2 (EP/RP), and, on select data security (S) devices, an integrated low-power crypto co-processor. PolarFire FPGAs can operate at 1.0 V and 1.05 V, offering the end user the ability to trade off power and performance to match the application requirements.
查看全文
