[原创] TI bq76PL455A-Q116路锂电池平衡参考设计TIDA-00817
关键词:电源管理 电池监测 电池平衡 bq76PL455A-Q116
时间:2017-05-26 11:15:09       作者:TI       来源:中电网
TI公司的bq76pl455A-Q1是用于高可靠汽车应用的16路锂电池监测和保护器件.集成的高速差分电容隔离通信接口允许16个bq76PL455A-Q1通过UART接口和主器件通信,监测和检测几种不同的故障状态包括过压,欠压,超温和通信故障.满足 AEC-Q100汽车规范,主要用在电动和混合动力汽车(EV, HEV,PHEV, Mild Hybrid),48V系统,能量存储(ESS)和UPS以及电动自行车和电动滑板车.本文介绍了bq76PL455A-Q1主要特性,框图,应用电路以及16路锂电池平衡参考设计TIDA-00817主要特性,框图,电路图,材料清单和PCB设计图.
The bq76PL455A-Q1 device is an integrated 16-cellbattery monitoring and protection device, designed forhigh-reliability automotive applications. The integratedhigh-speed, differential, capacitor-isolatedcommunications interface allows up to sixteenbq76PL455A-Q1 devices to communicate with a hostvia a single high-speed Universal AsynchronousReceiver/Transmitter (UART) interface.
The bq76PL455A-Q1 monitors and detects severaldifferent fault conditions, including:overvoltage,undervoltage,overtemperature,and communicationfaults. Six GPIO ports as well as eight analog AUXADC inputs are included for additional monitoring and programmable functionality.A secondary thermalshutdown is included for further protection.
bq76PL455A-Q1主要特性:
• Monitors and Balances 6-to-16 Cells per Device
• Highly Accurate Monitoring
– High Performance 14-bit Analog-to-DigitalConverter (ADC) With Internal Reference
– All Cells Converted in 2.4 ms (Nominal)
– Eight AUX Inputs for Temperature and OtherSensors with Input Voltage of 0 V to 5 V
– Internal Precision Reference
• Integrated Protector With Separate Vref forOvervoltage (OV) and Undervoltage (UV)
Comparators and Programmable VCELL Set Points
• Engineered for High System Robustness
– Up to 1-Mb/s Stackable Isolated Differential-UART
– Up to 16 ICs in Daisy-Chain With Twisted Pair
– Passes Bulk Current Injection (BCI) Test
– Designed for Robust Hot-Plug Performance
• Passive Balancing with External n-FETs andActive Balancing with EMB1428Q/EMB1499Q
• Can Help Customers Meet Functional SafetyStandard Requirements (For Example, ISO26262)
– Built-in Self-Tests to Validate Defined InternalFunctions
– Support for Open Wire Detection
• AEC-Q100 Qualified With the Following Results:
– Device Temperature Grade 2: –40°C to 105°CAmbient Operating Temperature Range
– Device HBM ESD Classification Level 2
– Device CDM ESD Classification Level C3
bq76PL455A-Q1应用:
• Electric and Hybrid Electric Vehicles (EV, HEV,PHEV, Mild Hybrid)
• 48-V Systems (Single-Chip Solution)
• Energy Storage (ESS) and UPS
• E-Bikes, E-Scooters
图1. bq76PL455A-Q1功能框图
图2. bq76PL455A-Q1简化电路图
图3. bq76PL455A-Q1主器件电路图
图4. bq76PL455A-Q1另一器件电路图
Reference Design describes a complete solution forhigh current balancing in battery stacks used for highvoltage applications like xEV vehicles and energystorage systems. The design implements active cellbalancing to compensate for both cell chargemismatch and cell capacity mismatch and obtain theoptimal efficiency of the pack for the lifetime of thesystem.
16路锂电池平衡参考设计TIDA-00817主要特性:
• Based on bq76PL455A-Q1 Monitor and Protector
– Highly Accurate Monitoring of 16 Li-ion Cells
– Integrated Redundant Protector
– 1-Mb/s Stackable Isolated Differential-UART
• 2- to 5-A Active Balance
– Fully Isolated Transfer to External 12-V Supplyand Battery
• Capable of Compensating for Charge and CapacityMismatch
• Up to 16 Stackable Modules
参考设计TIDA-00817主要应用:
• Electric and Hybrid Electric Vehicles (EV, HEV,PHEV, Mild Hybrid, Start/Stop)
• 48-V Systems
• Uninterruptible Power Supplies (UPS)
图5.16路锂电池平衡参考设计TIDA-00817外形图
图6.16路锂电池平衡参考设计TIDA-00817框图
图7.16路锂电池平衡参考设计TIDA-00817栈中系统详细框图
图8.16路锂电池平衡参考设计TIDA-00817电路图(1)
图9.16路锂电池平衡参考设计TIDA-00817电路图(2)
图10.16路锂电池平衡参考设计TIDA-00817电路图(3)
图11.16路锂电池平衡参考设计TIDA-00817电路图(4)
图12.16路锂电池平衡参考设计TIDA-00817电路图(5)
图13.16路锂电池平衡参考设计TIDA-00817电路图(6)
图14.16路锂电池平衡参考设计TIDA-00817电路图(7)
图15.16路锂电池平衡参考设计TIDA-00817电路图(8)
图16.16路锂电池平衡参考设计TIDA-00817电路图(9)
图17.16路锂电池平衡参考设计TIDA-00817电路图(10)
图18.16路锂电池平衡参考设计TIDA-00817电路图(11)
16路锂电池平衡参考设计TIDA-00817材料清单:
图19.16路锂电池平衡参考设计TIDA-00817 PCB设计图(1)
图20.16路锂电池平衡参考设计TIDA-00817 PCB设计图(2)
图21.16路锂电池平衡参考设计TIDA-00817 PCB设计图(3)
图22.16路锂电池平衡参考设计TIDA-00817 PCB设计图(4)
图23.16路锂电池平衡参考设计TIDA-00817 PCB设计图(5)
图24.16路锂电池平衡参考设计TIDA-00817 PCB设计图(6)
图25.16路锂电池平衡参考设计TIDA-00817 PCB设计图(7)
图26.16路锂电池平衡参考设计TIDA-00817 PCB设计图(8)
图27.16路锂电池平衡参考设计TIDA-00817 PCB设计图(9)
图28.16路锂电池平衡参考设计TIDA-00817 PCB设计图(10)
详情请见:
http://www.ti.com/lit/ds/symlink/bq76pl455a-q1.pdf
http://www.ti.com/lit/ug/tidubz7/tidubz7.pdf
以及http://www.ti.com/lit/df/tidrn59a/tidrn59a.pdf
http://www.ti.com/lit/df/tidrn60a/tidrn60a.pdf
http://www.ti.com/lit/df/tidrn62a/tidrn62a.pdf
bq76pl455a-q1.pdf
tidubz7.pdf
tidrn59a.pdf
tidrn60a.pdf
tidrn62a.pdf
