[原创] TI INA260高精度电流和功率测量解决方案
关键词:电源管理 电流和功率测量 分流器 INA260
时间:2017-03-09 13:09:01       作者:TI        来源:中电网
TI公司的INA260是集成了和SMBus接口兼容的I2C数字输出的高精度电流,功率和电压的监视器,监测电压从0V到36V.具有16个可编程寻址,集成了精密的分流电阻2 mΩ,误差0.1%,温度系数10 ppm/°C,电源电压2.7-V 到5.5-V,工作温度40°C 到 +125°C,主要用在测试设备,服务器,通信设备,计算,电源管理,电池充电器和电源.本文介绍了INA260主要特性,框图,典型配置电路图,高边检测应用图以及评估模块INA260EVM-PDK主要特性,框图,电路图,材料清单和PCB元件布局图.
The INA260 is a digital-output, current, power, and voltage monitor with an I2C and SMBus™-compatible interface with an integrated precision shunt resistor. It enables high-accuracy current and power measurements and over-current detection at common-mode voltages that can vary from 0 V to 36 V, independent of the supply voltage. The device is a bidirectional, low- or high-side, current-shunt monitor that measures current flowing through the internal current-sensing resistor. The integration of the precision current-sensing resistor provides calibration-equivalent measurement accuracy with ultra-low temperature drift performance and ensures that an optimized Kelvin layout for the sensing resistor is always obtained.
查看全文
