[原创] ST STGIF7CH60TS-L三相马达控制电源解决方案
关键词:工业控制 马达控制 IGBT
时间:2017-02-09 09:37:15       作者:ST       来源:中电网
ST公司的STGIF7CH60TS–L是小型低损耗智能模块(SLLIMM) IPM,10A 600V 三相IGBT逆变器桥,包括2个用于栅极驱动的控制IC和续流二极管,带延迟的3.3V,5V TTL/CMOS输入,主要用在马达驱动的三相逆变器,家用电器如洗衣机,电冰箱,空调机和缝纫机.本文介绍了STGIF7CH60TS -L主要特性,框图和应用电路,以及马达控制电源板STEVAL -IPM07F主要特性,电路图,材料清单和PCB设计图.
This second series of SLLIMM (small low-loss intelligent molded module) provides a compact, high performance AC motor drive in a simple, rugged design. It combines new ST proprietary control ICs (one LS and one HS driver) with an improved short-circuit rugged trench gate fieldstop (TFS) IGBT, making it ideal for 3-phase inverter systems such as home appliances and air conditioners. SLLIMM™ is a trademark of STMicroelectronics.
STGIF7CH60TS -L主要特性:
• IPM 10 A, 600 V 3-phase IGBT inverter bridge including 2 control ICs for gate driving and freewheeling diodes
• 3.3 V, 5 V TTL/CMOS inputs with hysteresis
• Internal bootstrap diode
• Undervoltage lockout of gate drivers
• Smart shutdown function
• Short-circuit protection
• Shutdown input/fault output
• Separate open emitter outputs..
查看全文
