[原创] Linear LTM4643超薄四路3A μModule DC-DC解决方案
关键词:电源管理 μModule DC/DC转换器 LTM4643
时间:2016-12-13 09:29:02       作者:Linear       来源:中电网
Linear公司的LTM4643是超薄四路DC/DC降压功率模块(μModule),每路输出3A,输出可并联以得到12A.模块包括了开关控制器,功率FET,电感和支持元件.输出电压4V-20V或2.375V-20V,输出电压0.6V-3.3V,主要用在FPGA,GPU和ASIC电源,PCIe和PCB背面安装.本文介绍了LTM4643主要特性,框图和几种应用电路以及演示板DC2453A主要特性,电路图和材料清单.
The LTM®4643 is a quad DC/DC step-down μModule(power module) regulator with 3A per output. Outputs canbe paralleled in an array for up to 12A capability. Includedin the package are the switching controllers, power FETs,inductors and support components. Operating over aninput voltage range of 4V to 20V or 2.375V to 20V withan external bias supply, the LTM4643 supports an outputvoltage range of 0.6V to 3.3V each set by a single externalresistor. Its high efficiency design delivers 3A continuousoutput current per channel. Only bulk input and outputcapacitors are needed.
Fault protection features include overvoltage, overcurrentand overtemperature protection. The LTM4643 is offeredin a 9mm .15mm .1.82mm LGA package with RoHScompliant terminal finish.
LTM4643主要特性:
nQuad Output Step-Down μModule® Regulator with3A per Output
nWide Input Voltage Range: 4V to 20V
nn2.375V to 20V with External Bias..
查看全文
