[原创] Microchip PIC24FJ1024GB61016位MCU开发方案
关键词:PIC24 MCU DSP
时间:2016-10-18 09:58:59       作者:Microchip       来源:中电网
Microchip的开发板Explorer 16/32用来设计16位和32位PIC MCU如16位PIC24, dsPIC33和32位PIC32系列产品.开发板具有mikroBUS™很容易采用MikroElectronika的Click Boards增加新的功能,同时还支持用于通信和电源的USB功能,主要用在高性能的应用.本文介绍了16位MCU PIC24FJ1024GB610主要特性和框图,以及开发板Explorer 16/32主要特性,主要元件分布图,电路图和材料清单.
The PIC24FJ1024GA610/GB610 family introducesmany new analog features to the extreme low-powerMicrochip devices. This is a 16-bit microcontroller familywith a broad peripheral feature set and enhancedcomputational performance. This family also offers a new migration option for those high-performanceapplications which may be outgrowing their 8-bitplatforms, but do not require the numerical processingpower of a Digital Signal Processor (DSP).
PIC24FJ1024GB610主要特性:
High-Performance CPU
• Modified Harvard Architecture
• Largest Program Memory Available for PIC24(1024 Kbytes) for the Most Complex Applications
• 32 Kbytes SRAM for All Part Variants
• Up to 16 MIPS Operation @ 32 MHz
• 8 MHz Fast RC Internal Oscillator:
- 96 MHz PLL option
- Multiple clock divide options
- Run-time self-calibration capability for maintainingbetter than ±0.20% accuracy..
查看全文
