[原创] Altera Arria V高性能28nmSoC FPGA开发方案
关键词:ARM® Cortex-A9 MCU Arria® V SoC FPGA 无线通信 有线通信 军用设备
时间:2016-07-11 09:44:12       作者:Altera       来源:中电网
Altera公司的Arria V是业界最高性能的28nmSoC FPGA系列,其硬件处理器系统(HPS)包含双核ARM® Cortex™-A9处理器(工作频率高达1.05GHz),外设和存储器接口以及28nm FPGA架构,具有最低的总功耗,可降低系统成本和空间.处理器和FPGA互连大于125Gbps总带宽,最低功耗的收发器速率高达10.3125 Gbps,主要用在无线基础设备,有线10G/40G线卡和GPON,军用设备,测试测量设备,医疗图像设备和多功能打印机以及广播设备.本文介绍了Arria V SoC系列FPGA主要特性,架构图,以及Altera®Arria V SoC开发板主要特性,框图,电路图,材料清单和PCB元件布局图.
Altera’s Arria® V SoC is the industry’s highest performance 28 nm SoC FPGA with the lowest total power for midrange applications such as remote radio units, 10G/40G line cards, medical imaging, and broadcast studio equipment. The combination of a hard processor system (HPS) consisting of a dual-core ARM® Cortex™-A9 processor, peripherals, and memory interfaces with flexible 28 nm FPGA fabric lets you reduce system power, cost, and board space.
Industry’s Highest Performance 28nm SoC FPGA
Up to 1.05 GHz dual-core ARM® Cortex™-A9 MPCore processor
4 hardened 32-bit memory controllers with up to 533 MHz memory bus speed and optional ECC
Processor to FPGA interconnect with >125 Gbps peak total bandwidth
Lowest System Power for Midrange Applications..
查看全文
